Hello all,
About 8 years ago, I got a US Stove 2421 wood stove and put it into my fireplace. See picture below. Well, I was enjoying it and everything was fine, until I got married. Actually it was a couple of years after I got married when the wife finally fessed up that she didn't like it because it "makes the house smell funny".
Part of this may be because of the way I run it, I try to get the fire going real good, then close the damper thingy as much as I can to get it to be more efficient. I hate the idea of all that heat just going up the flue, when it still seems cold in the house. (House is 1400sq foot A-frame). I think part of the problem is that the house is a bit "loose", and I get drafts coming in from places.
Also, sometimes I use a box fan to blow are around the back of the wood stove so the heat can come out into the room.
Anyways, wife complained, so we haven't used it in 2 years. It's getting cold again and with only electric heat, my wallet wants me to run the wood stove again... So I'm kind of at a loss as to what to do because I want to keep my wife happy, but I don't want to run the electric heat.
I'm considering the following ideas and/or combinations of them:
Your thoughts and impressions are greatly appreciated.
Brian
![[Hearth.com] Help: wood stove smell, and inefficency. (And keeping wife happy) [Hearth.com] Help: wood stove smell, and inefficency. (And keeping wife happy)](https://www.hearth.com/talk/data/attachments/218/218739-851ee9dbc59a12775e1748648b9bb5b8.jpg?hash=Zc_VnCUxOC)
- get a bunch of stove cement and try to seal up my stove. (Do I need to take it apart for this?) (Will it make a significant difference? I don't generally see "smoke" leaking out from seems, but I don't know where the smell comes from)
- Add firebrick inside the stove. (Currently it's just an iron box with a bed of ash in it)
- Add firebrick outside the stove.
- Move the stove further into the room and add some kind of exhaust heat extractor to raise efficiency.
- Replace the whole thing with a new stove or wood stove insert. (Do wood burning inserts cause smells like mine does, or are they better? Would I see similar efficiency with an insert, or does a lot more heat end up going up the chimney?)
- Add some kind of fresh air intake. (Possibly with a fan) (Maybe snake it down the chimney parallel to the 6 inch exhaust pipe to help the air temperature coming in if I can somehow keep fresh separate from exhaust so I don't get a smell.
Brian
		 You can get a new one for under 1K, or even find a used one on craigslist, although that's riskier and you have to know what to look at on a used stove. That said, a decent chimney-pipe setup could cost you almost as much as the stove. Sure, all this is a bit of money up front but you will save wood (cost if you buy it, labor if you get your own.) And a happy woman?...priceless.
