- Oct 19, 2012
- 64
I have had the hi300 for a couple years and never seem to get the heat out of it the way I anticipated and due to a back injury a havent installed the block off plate but it heats the 1st floor ok. Never does it get really warm. (T shirt warm) Thats another story for another day....Well yesterday was my second burn of the season which I didnt want to do as it was going to be about 60 degrees out but my wife was having her sisters over and I was getting out of here. So the temp is 55 and really windy as a Low was moving in and a hugh storm was brewing for later that day. I lit it up as I always do and immediately got a huge back draft and the house began to fill with smoke. Opened front and back doors of the house and partially closed insert door and no good. Couldnt stop the smoke no matter what I tried so i finally shut the insert door completely. HERE it got freaky.. Smoke started appearing everywhere like a Si Fi movie.. Passing through all gaskets and creeping along the living room floor filling the room. Around the door, around the glass with the decorative front almost like it was passing through the glass, sides and bottom of the fan housing. Every where it was appearing. Really wild to see. Now I had replaced my door gasket last year and the section on the bottom of the door has flattened more than the rest and I am going to order another and adjust the latch washers when I do but.. Has anyone experienced something like this and is it common for the glass gasket to wear out too as I now assume that must be shot? Is that hard to replace and how can I tell ifs its shot? BTW my wood is very dry hardwood some going back to super storm Sandy. Finally does anyone know where to get these other than Hampton Regency as their prices are crazy and are there any tutorials for replacement of these gaskets so I do it right.
OK, While I am at it, my chimney is an exterior wall chimney and I am wondering if there is anything non flammable (Pliable blanket like material ) that I may be able to slide behind the insert to insulate back there. Sorry for the blah blah blah and thanks for any tips..
