We installed our first stove six years ago (Regency F2500) and have been using it as our primary heat source since then. Have learned a ton from everyone here over the years, definitely been a great experience so far. Had our first fire of the season tonight and had new situation. Hopefully I'm being a little paranoid but would rather be safe.
Outside temps in the low 50s dropping into the low 40s overnight so I put a small load in the stove to keep the chill off the house. I followed my normal cold start process, some paper to heat the fire box and the draft going, then a small top down, took a little time to really get going leaving the air all the way open, normal for these outside temps with a cold stove.
Temperatures measured with IR gun, ~18" above stove for chimney temps.
Chimney temps had seemed to settle around 350°F with the stove around 300-350°F. I was waiting for the Cat to come up to temperature to try to activate it, normally takes a longer with a small load so I check it approximately every 5 minutes or so. When I checked it the pipe has jumped up to 500-525°F and the stove was up to around 400°F put the Cat in, lowered the air slightly (normal process) and kept a close eye on the chimney temp as normally it stays around 350-400°F maybe pushes to 450/475°F when I'm running it harder, mainly based on recommendation from the installer. Chimney temp kept climbing, as it approached 600°F I closed the air all the way down, kept climbing, went outside to check the chimney, thinking maybe it was a chimney fire, no flames, no embers, no red glow, no roar from the pipe, normal color and amount of smoke. Chimney temp peaked around 675-700°F, held there for a short period, then slowly started to drop back down. Stove never really got much over 400°F.
Whole thing probably didn't last more than 2-3 minutes before it leveled off and started to drop but definitely got my heart rate up a bit.
Once I calmed down a bit I'm thinking this was potentially just the wood off gassing hard and temps spiking from me leaving the air open too long, but the chimney temps being that much higher than normal and the stove temp being that low has me a bit puzzled. Is this something I should be worried about? I know single wall pipe is rated for the temps it saw but could this have been a chimney fire? Appreciate any thoughts/insight anyone can provide.
