Hole above chimney
Yavne
50
Nova Scotia
Hello all,
A few days ago I cleaned the chimney, and I noticed a small gap, where chimney connects to the wall.
Is there a need to fix it or we can live with it?
[Hearth.com] Hole above chimney
Thank you!
If you can do a simple airleak test might tell you? Probably okay just to put some high temp sealant around it. Looks like that's what they did anyways.
Reactions: Yavne
Thanks guys! I will be at home later today, I will take a look. I think some sealant missing... Should I use Stove & Gasket Cement?
I think I can use the woodstove in the meanwhile, right?
