If you paid for insulation, then it should have a foil coated blanket around it...like the video.the manager called and said he agreed with me, that more insulation and a top plate should be there.
A reasonable option is to break out the clay liner. I had that done on my chimney for that exact reason. That said, I not sure I’d want that company doing that and messing things up further. I don’t think it’s too late to ask for your money back and find a better company. I’d question if they even know how to make it right.Thanks for sharing this. I asked about this during the install but they said the tight space made it too tight to dif a proper liner and the wrap so they opted to do the filled thermal insulation material.
I would most likely break out the clay in your caseI see. Thank you for your input I'll keep all posted
Maybe a plan of action and items covered should be reviewed with the owner before they proceed.You can bet they’re going to try and reuse that crushed liner. They’ll do just enough to make it look better from on top. My prediction.
At least it doesn't matter much if they spit on your liner...but the steak is another matter!Thats why I brought it up. Warning! It’s like sending a steak back at a restaurant, at best they’ll microwave it for a minute to get it less pink. It’s not like you get a new steak.
At least it doesn't matter much if they spit on your liner...but the steak is another matter!![]()
They cemented the top of the liner in?Wanted to give an update. The crew came back. Polite but definitely didn't seem as friendly as last time haha - maybe it was in my head.
Anyway, they pulled the liner, put in one that is actually insulated (looks like an insulation wrap around the liner, rather than the packed stuff from before). They then cemented the top of the liner where it exits the terra cotta to create a custom top plate, as they didnt have that fit the custom ovalization needed. He took photos of the entire process to show me, including a photo of the insulation coming up all the way to the top of the terra cotta, before they cemented over it. It looked a lot better this time - cement job seems good, the oval shape was better looking, and the insulation was the type you guys talked about here. I'm much happier now.
Not doing another fire today though - it's HOT! Also waiting for it to cool down to inspect the work on the chimney but the photos were detailed so I'm not as anxious this time around.
Thanks for the help everyone...
Maybe they used that pour in cement/liner product?They cemented the top of the liner in?
So what is going to give when that liner heats up and expands? Something is going to have to give. That means either cracked masonry or kinked stainless. I can almost guarantee it will be cracked masonry. There is a reason no liner manufacturers instructions tell you to do it that way.Yes. Seems uncommon but I've seen it done before and advertised on other installer's websites online.
Here's a couple example photos of what I mean that I found online. Similar to this. I will post a picture when I go up there this week, but it looks like the first 2 specifically. They put cement/concrete/masonry between the terra cotta and liner.
If it is a custom oval liner it needs a custom oval top plate.
The chimney looks pretty conventional to me. They just apparently make up the way they want to do the install instead of following the instructions and ul listings.They said it was a very unconventional Mason chimney sadly.
My 2 neighbors' homes were built by the same builder in the 70s and apparently another guy was told by an installer they couldn't even get a liner to work properly.
I've burnt a few fires in 80f weather and despite the heat got a nice draft going. I think it'll work out.
