How concerned should I be about this white mold?
Llilith
29
Portland, Oregon
We just had a cord of wood delivered and there is alot of white mold (or fungi, I'm not sure). It is a mix of alder and maple. How concerned should I be?
[Hearth.com] How concerned should I be about this white mold? [Hearth.com] How concerned should I be about this white mold?
I guess if white mold is bad I would have died some 50 years ago
Normally it is a by-product of wood decomposition it dies off as wood drys
in most cases
I'd not be too concerned about the mold, but if you have people that are sensitive to mold in the home, leave it outside, covered and off the ground, and bring in one load at a time that you put in the stove right away.
It is a sign though that the wood was.wet a long time . likely piled on the ground. It is likely not dry enough to burn...
Thank you both for responding. I do have mold allergies so I suppose I shouldn't bring it in the house. My moisture tester needs new batteries and I'll be able to check the moisture tomorrow. I'm pretty bummed my husband accepted this, but I want to make sure I'm not making a big deal out of nothing. If this is normal, then ok. Is this to pretty common? I feel terrible cause he stacked it all and now I'm like nope... Maybe it's much ado about nothing?
Split a few pieces tomorrow and measure. Get the data before getting too harsh on your husband:-)
Alder decays quickly, especially if damp and on the ground. Check to make sure the wood is not punky by resplitting a few. If it is still hard and solid then it's ok to burn. If the wood is mushy and soft, even though dry, I'd leave it out on the ground to return to nature. Punky alder burns very smokey and tends to smolder. I used to use it in my bee hive smoker.
