How do I make this work?
TMRhearth
2
Superior, WI
I'm using Selkirk DSP double wall stove pipe and I need a section about 9 inches in lenght. They make 6 inch sections and telescoping sections that start at 12 inches. Selkirk also makes DCC pipe that is adjustable from 2.5 to 5 inches. That would give me the correct lenght if I combine it with a 6 inch section. Is the DSP stuff compatible with the DCC stuff though? Are there any other brands that are compatible with the Selkirk DSP? Is there any other way to get a 9 inch length of double wall? This really shouldn't be that complicated....
Stick with a matched set with your system, if you can. I don’t think any manufacturer will offer to mix pipe or fittings and claim it is safe. Same goes for insurance companies. Can you raise the whole pipe above the roof penetration to keep the factory 12” + adjustable pipe?
I had to move the stove closer to the wall. There was no other way to make it work since Selkirk doesn't make a length between 6 and 12 inches in DSP.
