My neighbor had a huge tree taken down and did me a “favor“ by having these wood rounds dumped in my backyard When I wasn’t home . The majority of the tree was great- 18 -20” long rounds, – but I am not sure how to handle these for stacking.
Thicker? They already have a thickness, so I don’t quite get that. And what is shoulder season?Split into thicker than normal splits, keep separate from your normal stacks, and use for shoulder season.
Noodle if needed then split as usual.
Do you put them on a regular type rack or Pallets? On a regular rack they would fall through or cause the stack to be unstable Do they take longer to dry?When I have rounds like this, I split them as normal and then place two of them in the stack where a normal split would go. They are usually about half the length of a regular split.
I do what others have posted after splitting:
If small enough … two get stacked together.
If they are large enough … they just get stacked normally.
If they are really weird … they go on top of the log pile.
I actually like them since I can use them as wood for my offset horizontal smoker, and I don't have to cut regular firewood logs after splitting smaller.
