How Do You Clean Your Pellet Stove Glass When It's Hot?
sydney1963
770
Windham Maine
If you're running it 24/7 how do you clean it. I have tried opening the door while it's running and taking a wet paper towel to wipe it but it leaves streaks. Any other suggestions?
Vac it with a round brush attachment soot flakes right off.
Excellent, I'll try that. Thanks millions!
I would think you might melt whatever vac attachement you use. I actually just came across this problem this morning. I tried the slightly damp paper towel, and got it good enough. I was nervous I might crack the glass, so I used as hot water ad I could get on the paper towel.
My firebox is pressurized, can't open it while it's running. Those pesky sparks and flames would go everywhere.
I do clean the glass at every shutdown opportunity, though. A dry paper towel does the trick.
Hi. New guy here offering my 2 cents.
With "company" coming for tomorrows holiday, SWMBO wanted the glass spotless on the XXV. It normally runs 24/7, so I simply shut it off. Within about a half hour it was just "warm" to the touch, but certainly not "hot". Favorite window cleaner and a half dozen paper towels and it was spotless.
FWIW I normally vacuum the window, spray on the window cleaner, wipe it dry. Then spray more window cleaner, wipe it dry. If needed due to leftover streaks I might have to lightly spray it and wipe it dry a third time. By then it is usually spotless.
How about a warm damp wash cloth I don't think that would leave streaks?
Wouldn't put anything wet on hot glass.
I wipe it down with the stove running.
Takes about 15 seconds. I use a dry
paper towel (no scratches I buy the good n soft ones)
or if I don't have any paper towels I use...
I know you guys aren't gonna see this one
coming, but for real I use a dry maxi pad.
Do not put water on it unless you wish to
risk possibly cracking your glass.
Brother thought I was nuts but it works
so what they hey.
I wait until I do a quick cleaning and do it then while it cool...
For the very quick clean, I shut it down and wait for the blower to turn off. With my Napoleon, it takes about ten minutes from going full bore to shutoff. I do something else with my time rather than wait around, like go to the garage for another bag of pellets.
I scoop out the firepot with a long metal spoon and dump the embers, clinkers, and ash right into the grill on the side so it falls into the ash pan. Then I take a soft bristle paint brush in my right hand, and a rag in my left, and brush the window quickly downwards so the fly ash drops onto the rag. Then I brush the rag off into the wastebasket. This whole procedure takes about one minute, and I'm up and running again.
By the time my blower is shut off, the glass has cooled down enough not to melt the paint brush bristles. Your Mileage May Vary, so test it in a small corner of the glass the first time. This procedure is good for two or three days, then we have to do a thorough shut-down, cool-down, vaccuum-out cleaning, including using a solvent-based stove glass cleaner followed up by Windex. That takes a half-hour of cool-down time and 12-15 minutes of cleaning. With our Athens pellets, we get a build-up of ash under the burn pot so this full clean can't get put off for a whole week.
Another tip: When we get done with cleaning, I take a handful of pellets and put it in the burn pot before closing the window. It takes much less time to ignite, hopefully using less electricity and extending the life of the igniter. I'm going to test that theory with my new watt meter, but at least the fire gets cranking sooner.
First, let me say that after burning wood stoves with glass doors for 30yrs?...After the first month I could have cared less about the clean glass. Just looking over at the stove and seeing that nice warm glow is all I ever needed.
With my pellet stove, when I'm doing a normal ash sweep about twice a week, before I close the door back up I take a window scraper with a razor blade in it and just quickly scrape the windows. takes 10secs. I don't care about streaks, etc...and I refuse to get anal about having a picture perfect "flame view" of the burn pot.
Anything you do with a HOT stove and HOT glass is nuts, and you're begging for an accident. Just not worth it.
Enjoy the glow!!! :)
Jim
Holy crap. I used to shut down, clean the glass, vac the burn pot, vac the ash pan and generally vac everything i could easily reach daily. Took about 20 minutes a day including cool down time. I can't believe some of you go 24/7!
I've a had great results from a little windex and a "magic eraser". You know, they are those white little sponges that are used for taking marks off the wall. It cuts right through heavy soot on the glass.
I use a turkish type bath towel....after the stoves convection blower is off....I don't get much or any black soot on the Englanger at all...The GlowKing needs a full shut down and we use woodstove glass cleaner on that...
Like I was taught when I worked for J & J Depuy...
Wear your PPE (personal protective equipment) while
working with hi temp ovens, etc. The proper protection is key.
For thr time it takes to shut down long enough to cool the glass you can do a mini clean while your at it and clean the glass . If in the half hour this process takes your house cools down that much I'd say there are bigger issues afoot. I perform a shutdown every Saturday morning and this gets done then.
I've been using a dry microfiber cloth. I noticed that even if the cloth is not clean because of repeated use, it still works very well; no streaks at all.
I will be using newspaper next time I clean it. I used to use newspaper years ago on my windows. Nothing cleans glass easier and streak-free than newspaper. It's chemical free for the most part, and economical.
Jim
Paint scraper witha razor blade on the front. Works excellent at any temperature. unless your anal about a few little streeks
:bug: I dont clean the glass-ever! when its hot..never-never. It is not worth voiding the warranty or an accident. Jim and I have just a slightly different routine. I am home the most-so I do 3/4 of the cleanings.He always hauls the bags in & loads-as he has more muscles than me.But I do help him load pellets in the garage. If the sun is out-its perfect- :-) and I can shut the stove down for 4- 6 hrs.But I'm also learning that I lose some of that thermal storage heat thats built up in the house the colder it gets outside. Then its an easy clean. Even on the cloudy days- I still wait for the glass to cool good before cleaning the glass,otherwise its a quicker clean with the paint brush and scoop out ash with the metal spoon. Right now I have the oil to use up in the tank-so I really dont have to let the house cool down if I dont want-and thats set on 60*.In the future-it will be a propane back-up or wood stove. I use the special stove glass cleaner-then windex-dry it good, but am going to try some of these other suggestions also. For whatever miniscule heat radiants from the stove or pipe- we put a piece of radiant barrier behind the stove to reflect it back into the room. We hang the special tool-paint brush & a pair of scizzors from hooks right there-the rule is "they stay there", and a medium size ash bucket with lid,and the small shop vac hanging on its brackett-right nearby. We definitely want/will buy a real ash vac,as it makes us a bit nervous. We both put a handful of pellets in the burnpot for starting up procedure.
I get soot streaks on my window, but if I don't let it go more than a couple of days I have found that the thick baby wipes with a little stove glass cleaner squirted on them seem to work quite well. I usually take two, fold them several times, spritz a little of the cleaner on it - a few passes gets the worst of it off, and then I unfold the wipe a bit and refold it to a clean surface to finish the job. The only thing you have to be careful of is when you feel it start to get hot, get it off the glass. It only takes a couple of seconds to go from hot to steam burning your hand. I have done this a dozen times or so when the stove is running, and have yet to have a problem.
---scott
With a Quadrafire mt Vernon stove, shut down is about 10 minutes. Open the glass, scrape the pot, open ash slider to let ash out of burn pot. Vac out fly ash in burn chamber and windex the glass...Total time....5 minutes at most. Start up stove again and burn baby, burn.
