Polar Bear
I ask my father to bring his dual axle trailer... otherwise I'm only loading 10-20 bags at a time.
You may want to throw them on the conveyor and let her stack - if you're stacking right next to the conveyor. I use a plastic slide through my basement window and set the bottom on a table. The stacking part in the basement isn't as much work as bending down and putting every bag on the slide. If your conveyor (or slide) just barely sticks out of the basement window, the part outdoors is harder work and hard on the back.OK, new to this, got my 2 tons delivered in the driveway, and over three days my wife and I carried them into the basement, right through the house (and unlike firewood, no debris to clean up afterward!) I'll say this, while she complained a bit she never slowed down; I could have stopped for a beer and she would have kept on going.
The stairs were of course the least-fun part. I have an outside stairwell I have not been using, and I just roofed it over (w/walls, doors, etc). I'm thinking about setting up to get the bags in via that, and at first thought about a schoolyard sliding board and was wondering about what angle would suffice to get them to slide. Then, here at the office, they are reconfiguring the warehouse and I was looking at a leftover section of roller-conveyor, and hmm, I know the bags should roll on that (foam rubber stopper at the bottom). I could load up, eh, 25 bags at a time in the utility trailer behind the car, drive the rig around behind the house, and as fast as the wife could toss them on the conveyor, I could pull them off at the bottom and stack.
Someday I'd like to get one of those roller conveyors that's long enough so I can set it on the table inside and support the outside at waist height. Then both ends would be easy on the back. If your conveyor is like that, will you update the thread so I can hear how it works out?
Those are actually clouds painted by my wife. This was a kids lounge area and she wanted it to be less "basement like". Now they have moved to the other side of the basement where they have a lot more space but no clouds (at least not yet).Looks good. Drawn to the clouds/drywall mud haha
This was last years setup along the walls.
The Lignetics were very hot, with a little less then average ash. One of the hottest pellets I tested last year and I would buy more if they were so expensive here. Only one dealer locally and they want $300 ton! For that much I can get Lacrete's which should be even hotter and significantly cleaner. The Lignetics were almost identical to the Green Team Platinums (within 1 degree) and similar ash, but I can buy GTP's for MUCH less money, so I went with several tons of those instead.
First year I stored them in the garage, 4 tons which I restacked onto 3 pallets. Garage humidity gets pretty high and they were in my way there, so last year I moved to basement storage along the walls. I built simple racks to store one row deep, made from 2 x 4's (3 per rack) and 3/4" thick high density particle board. Saved a lot of room versus pallets (at least for me).
This year I've added a second stove in the basement and moved some things around. Modified 2 of the racks to fit into an alcove area (lost about 1 ft each) , so 2 rows deep now, and put the 3rd along an adjacent wall. So here is 6 tons stacked nicely in a small amount of space while still being accessible.
(broken image removed)
