How insulation works
Ctwoodtick
2,389
Southeast CT; NW Maine
in searching this site, I see that liner insulation” reduces” heat transfer and other descriptions saying that it “slows” heat transfer. Are the two terms being used interchangeably or is there an actual difference in terms?
It does both by greatly reducing conducted heat from the liner and slowing down or reducing radiated heat.
Interesting. How much of the radiated heat would you figure is reduced by the insulation wrap?
It does not block air flow though.
Do you mean airflow from liner in form of heat radiating from liner?
Not sure what air flow you are referring to. Liner insulation really does not have to deal with airflow but it is foil faced so it would
The rate of heat loss through a material depend on both the "R" value of the material and the temp difference from one side to the other. If the rate of heat transfer "slows" then the total amount of heat lost over some period of time is "reduced".
Reactions: illini81
I had block off plate vs stuffing insulation stuck in my brain, my mistake.
That was what i thought you were thinking. No big deal.
