Well, cloning the stovepipe onto the tile makes it look like a 6" flue.
I think I remember reading somewhere that very old pre-EPA Kings had a 6" flue? Not sure about that.
Get the model number off the back!
I will. This is almost a brand new stove I think. The house is only 7 years old and when the house sold in 2014 it did not have the stove. And I was told it was bought new.
Just wanted to get a heads up before I go inspect the house on Saturday which model this is.
I would question that because I don't see a cat bypass handle. Maybe it's hidden on the other side?
I would worry more about the install than the stove anyway. A new stove is pretty cheap compared to a new house.![]()
Any offers?I’m expecting to have an accepted offer in the first week.
Any offers?
Dunno. I don't think it looks like a current princess or king. I will have to defer to the experts on this one.
Here's a princess on legs from BK's website.
Thanks. Other then the color of legs it looks very close to me. But pictures are deceiving.
Yeah, the apparent ratio of width to height is not the same, but it could be in the photos like you said. Check the tag!
I'm moving to Idaho. It takes 3 years to sell a house here.On our house? Yes we had 5 offers. A couple over asking but we went with some local folks that seem to be good people and they offered a little under asking.
And then we put an offer in on a different house and they accepted.
So operating on the idea that it’s a princess. What do I need to look for stove wise? Not including the install. I don’t know a whole lot about the cat stoves other then how they function.
We inspected the house today. While there I took a look at the stove. It seemed to function properly. The cat was very white and looked kind of brittle. Is this normal on these stoves?
Yep....another Blaze king thread!
Our house goes on the market the first week of Feb. it’s a hot market and we have the ideal house and we are priced slightly below market value. I’m expecting to have an accepted offer in the first week.
The houses we have been looking at have been around 2100 square feet with vaulted ceilings. Insulation levels standard for houses built in the 1990s.
I like the idea of the king over the princess because of burn times.
I’m hesitating on going that size because of the problem I had with the Englander 30 overheating my house but I realize that the BK are cat stoves and will perform different.
I would rather be a little colder then be to hot.
Is it realistic to put a King in a house around this size or is it overkill?
I read the ratings but I have no faith in SF ratings of manufacturers because of all the variables involved.
I would love to be able to load the stove one time every 30-40 hours.
I'm on my second King ,had the regular king pedestal for a few years but traded two years ago for a King Parlor.
Get the King better to have the extra juice and not need it then to need and not have.
Forget about 30 to 40 hrs burn times,unrealistic but can be done in mild weather,realistically in your well insulated layout 12 to 14 hours between reloads.Can be every ten in bitter weather conditions.Get the ash pan works well enough.My house is at 1800 one level and I have no complaints,cut her back for less heat,crank up for more. A great stove love mine.We've had the coldest winter here in five years and no probs,wood consumption is better than my last BK which baffles the hell out of me ,and startups are quick,nothings changed? Anyway good luck.The BK is a frugal wood consumer for the most part,however colder weather = more wood consumption ,most I've ever burned was about 4.5 cords in a brutal winter about five years ago.
Sticker says it's a Princess. It still doesn't look like a princess or a king to me in that first photo! They ship with ceramic cats, so yes white and yes brittle. The cat shouldn't have been visible unless you removed the plate that sits in front of it.
Honestly after 7 years of unknown things being burned in there, be pleasantly surprised if the cat works, but be prepared to replace it also.
It was built towards the end of 2010 I think it said on the sticker. Not sure when the design changed.
When I looked up inside the stove I could see a white brittle looking honey comb like structure. There was a plate covering it but each side had fairly big holes that I could see thru. I should of taking a picture but it looked factory designed. Didn’t look like someone modified anything.
