I have a VC Resolute Acclaim (later model) stove. Finally got it set up a day+ ago. (life does intervene! It got reallllllly cold!!). After operating the stove for 8+ hours - I came home (gone the last3+_ hours) to an ever-so-slightly smoky house; eyes burned and slightly visible 'smoke' in the room.
Is there any reliable way to determine where this likely ever-so-small leak is coming from? I tried closing down the stove to create lots of smoke and carefully scanned the outside of the stove (no fans - no discernible air movement) and could not see any smoke coming from the stove.
Also - I am not convinced the stove pipe (and 3 joints: stove to pipe; and 2 junctions of 3 pieces before the ceiling box) is not leaking smoke. The pipes are all Durablack pipe - supposedly seal sufficiently w/o some glue/sealant (no such instructions to use such material). Is there a material/glue/substance I can use around the joints to 'seal' the pipe and be sure they are not leaking ever-so-small-undetectable smoke?
Appreciate your time
Kelly
Kelly
! I had the house open all morning in 17F temps; cooked the stove to nearly 'overheat' just to 'burn off' off the nasty gasses as fast as I could from the stove pipe paint! YIKES! Had to open the front door/back window, turn on ceiling fans and furnace just to try to blow that toxic smell out of my house as fast as I could. I'm sure it's still off-gassing, but not nearly as bad. (I'll be suing DuraVent should I come down with lung or some other cancer next year!). I had run the stove yesterday, but a a lower temp to 'break it back in' after at least 2+ years of non-use. so I didn't fire it up full first day; I noticed the smell several times last night while trying to sleep!
