How to tell if your wood is dry enough.
babalu87
1,440
middleborough, ma.
With your lips?? Yah, I can see my wife asking if the wood is dry enough and I tell her to shove it in her mouth and blow!
omg that sure opens the door...............honey, will you come blow on my wood?
You really need to read the Oil post in the ash can
babalu87 said:
This is from the Morso website.
You can check yourself whether the firewood is sufficiently dry by smearing detergent on one end of a log and blowing through the other. If the soap bubbles, the firewood is sufficiently dry.
Take that VC ;)
http://www.morsoe.com/us/Before_buying/Fuel_types/
HA, HA, IT ACTUALLY WORKS! I was dumb enough to try it. So Babs, have you tried it yet?
The mind boggles. I have this mental image. All over the country tonight people will be...
Havent tried it , I just found it on the MORSO website today
and this from the same website.....
"Coke contains little gas, and only few stoves are designed for coke firing as it requires a thick layer to ensure a good fuel economy. Morsø’s 3310 is specially designed for coke firing."
That really doesn't sound economical to me.... I'm not sure how many BTU's it has in it... plus try explaining that to the DEA officers when they come a knockin' on your door in the middle of the night... "but officer... those 20 kilo's out in the shed are for heating the house... really!!" :smirk:
Very nice, but, that's nuts. I'll stick to banging a couple logs together. Or checking the weight. Or maybe not caring all that much log to log, because mos tof the pile's dry, and the couple that aren't perfect will be plenty dry about 10 minutes after they go in the stove.
Steve
Makes you wonder how they expect you to tell if you are running your stove too hot :gulp:
Want to try that with this stick O wood?
  • How to tell if your wood is dry enough.
wrenchmonster said:
HAHAHAHHAAHAHAHAHAAA!!!!!
-Kevin
That is some hornbeam you want to watch it when you cut it as you often find some neat stuff.
Here is one I used as a railing corner post on a stairway landing.
Two questions. 1. where is Monica
2. What is is
Y'know, I was just sittin' back enjoying this thread and then I saw Andre's pix. Suddenly I feel so, so -- violated! Dirty! Ashamed! I think I need to go take a shower :grrr:
On a lighter note, I actually persuaded Wifey to try the blow-on-the-split test, though only after several tall glasses of her favorite white zinfandel. Unfortunately, I had no splits in the storage ring that even remotely resembled the ones in Andre's collection. Even worse, I didn't even get any pix.
As for myself, I'll stick with my trusty 20-buck moisture meter from Chinese Frei, rrrrr, I mean, Harbor Freight:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2757
