W
WellSeasoned
Guest
Its been 2 weeks since I split last, but I'm constantly refilling them with air. Just wondering if anybody else has this issue with this particular model, thx
Just put tubes in, they are around $10-12 at Lowes for those small tires.
Sometimes older tires just won't hold air, it's not like you can just plug a hole. Air can leak around the bead or just seep thru the rubber if old and dried out. Tubes take care of these situations.
Good suggestions guys! I have thought about slime, but will check valve, ect first, thx
Dish soap n water, squirt it around and see where it's leaking, and go from there
Find the source of the problem (ie. the leak) and pick a solution from there.MasterMech can install them for you. (ducking)
Don't waste your money on that crap. It's about as useless as fix a flat. Almost never works and they you have that nasty crap to clean out to actually repair the issue.
Slime sells tubes that have the goop inside already. No mess. If you're gonna tube 'em, it's an option.
Mine working fine so far. 3 yearsJust wondering if anybody else has this issue with this particular model, thx
I heard that Alaskan air lasts forever in a tire.Mine working fine so far. 3 years
I heard that Alaskan air lasts forever in a tire.![]()
I was gonna put tubes in something or other, generator?, but then realized I didn't know how to take off the tires. I've done bicycle tires but nothing else. Any links on how? Bigger tire irons, I guess.
