Husqvarna 350 or 55 - which would be a better choice, and is this a good price for either?
newstove
139
Central MA
I have the opportunity to buy either a Husqvarna 350 or a Husqvarna 55 Air Injection.
Both have 18" bars, decent chains, and both are in pretty good shape.
I can have either one for $200.
Which would be the better choice? The 350 appears to be more highly recommended in various readings I've done online.
Any opinions? Is it a good price for either in good shape?
Also, I may like to put on a larger bar if possible for once-in-a-while-monster-log-cutting. What would be the max bar I could reasonably put on either one?
I think I'm leaning towards the 350...
Thanks!
I'm happy with my 350 but wouldn't go longer than 18", in fact I've gone shorter. Unless it's in great shape, $200 seems high as you could find them on sale for around $300 new. If you get it, make sure it has had the muffler recall done (you'll se a third bolt (at the top)).
If you think you might get into some bigger stuff, I would look for something closer to 60cc.
Thanks!
$200 for a used 55?? Seems like quite high! I paid $70 w/20" bar/chain
Thanks!
Hehehe... That's why I asked the questions. ;-)
I'm not really a Husky guy - these just kinda fell into my lap as a, "Hey, wanna buy a saw?"
I've already got 2 16" Mcculloch saws that cut anything I throw at them, but figured if I could get a deal I could put a 20" or 24" bar on for that once in a long time when I gotta cut something really big, it might be worth it.
Although the price is on the high side if you can get it lowered, I would choose the 55.The reason? Well the crankcase on the 55 is magnesium compared to plastic, parts are easily available and the 55 is a gem to work on. How do I know?I bought a used one from a pawn shop, cleaned the cylinder, replaced the piston and ring. The saw now has 165lbs of compression and pulls an 18 b/c with a 3/8 chain with know problem.
Can you tell me about the muff recall? I have a 10 yr old 350 and the bolts are tight. I have checked them and they seem to be holding.
Jim
I don't know the years of production but they had changed the muffler designed and the two bolts weren't holding so they had to had a third. I think it was in the '07-early'08 range so you are fine.
NewStove,
I have had really good luck with my Husky 350. It starts up and always works well for me. Its not a pro logger chain saw, but If I cut 5 cords of wood this year I am doing well with this saw. I put the Full chisel chain on and it cuts great.
The 350 has less vibration than alot of other saws and youll be liking that.
Jim
I have a used Husky 55 that I bought for $130 bucks with an 18" bar and a dull chain.....It's been a great saw--starts right up every time and blows through 24" inch trees with the new chisel chain with NO problem......Given that a new Husky 455 retails for $420, I don't think $200 is at all unreasonable IF it's in good condition. I tested the compression on mine before I bought it: 150 PSI cold.
From what I read, folks seem to think the older Rancher 55 is more robust than the newer Rancher 455, and, I think the 455 carbs are not adjustable--but that just may be limiter caps that can be taken off (though voiding the warranty...).
Regarding buying two new saws, I agree with others that it seems like a waste of money to me--just buy a 16" bar and chain if you want more control and precise cutting. About 6 months ago I picked up a used 45cc Craftsman at a yard sale for $20--they bought it, used it once (it scared them.....) put it back in the case and sold it. It's smaller and lighter than my 55, so I use it for limbing and for a backup saw on my scrounge runs in the Natl forest.
NP
