Tree guy wants me to build a processor for him. He brings over a pole saw and says the bar and chain can both be bigger. Assuming this is true, is this thing going to have enough power to be worth the effort of adapting and installing it?
I'm gonna go ahead and say no. It'd be like cutting a 20 inch oak log with a weed eater engine. I am a hydraulic engineer by trade and could do a power analysis if you know the displacement of the saw motor and pressure rating. I suspect it wouldn't be near effective unless you spin it at 100,000 rpm with chain speeds approaching the speed of sound.
This confuses me Dune (not really hard to do.The thing is, even if this little saw took ten times as long as a larger one, it would still be an increase in production for the guy.
This confuses me Dune (not really hard to do.). Why would a person want a processor if not for output speed? Using a tiny hydro pole saw for this seems...well...counter productive.
Holy jeepers. He would be better off to hawk the saw and get a proper hydro motor and put a few of the bucks saved back into the machine.
I think I just helped your Cape Cod mindset. See above post.If it doesn't have a prayer of working, I'll try to do something else, but this is Cape Cod after all.
I wouldn't really call it a total joke. If he was constantly running 12" or less logs, it may have its place, but for more typical log stock its gonna be a stretch. I would guess that the pole saw could bring a pretty penny on the market. Turn around and put that towards a more favorable hydro motor and then build on..Total joke? OK, that's why I brought the topic here. I don't know jack all about hydraulic chainsaws.
To start off, I would try to size up what the processor is going to be dealing with. Size that to comparable processors on the market and then look up the pump that it uses. Keep in mind that behind this motor your gonna need a drive (pump/engine) to match the requirements. Of course you have to figure in all the other drags, such as the splitter itself, the log mover, lifter (if needed), conveyor, blah, blah blah.
The sale of that pole saw would buy a pretty darn nice chain saw and have some bucks left over. Down side is that a hydro saw doesn't need to stop to re-fuel.No thoughts of mounting a gas saw on a pivot? Saves an awful lot of fabrication and $$. Lots of smaller processors run this way.
He is going to power it with an extra circuit on a boom truck or skid steer.
Is the plan to feed multiple control valves at the processor (in feed, saw, splitter will all need hydro)
Multi-way wedge with big azz cylinder?Yes.
At minimum flow and pressure the horse power would be about 2.5 at max pressure and flow around 8, So it's in the range of decent hand held chainsaw.
Surpluscenter.com has some reasonable hydraulic parts from time to time
Thats why I was asking the questions of flow and pressure above.So it sounds like it would work if it were fed enough juice.
Still working on getting the exact specs.Thats why I was asking the questions of flow and pressure above.
