We bought a house seven years ago and there was a wood stove in the living room. It's a Hearthstone Phoenix. The previous owner was mostly using it as an interior decoration and didn't do much heating with it. We decided to heat the house with it and did. Seven years later, all stones are cracked and when it gets really cold outside, we live in western Quebec, we have to run it with the damper fully open and refill it every hour to get it to maintain the house at a comfortable temperature. That tells me that, for what we want to do with it, the stove is too small.
Here is a floor plan of the first floor of our house.
![[Hearth.com] I badly need advice on stove size. [Hearth.com] I badly need advice on stove size.](https://www.hearth.com/talk/data/attachments/197/197478-f116e8552870cfee641a85cbddc115c8.jpg?hash=u45JgjfawU)
The house was built in 1997 and is well insulated. The location of the stove is really not ideal but we won't change it. It gets hot in the room where the stove is located but it's manageable. The first floor is 1100 sqft and the second floor as well. The second floor gets heated over the course of the day through the vent and staircase. It remains colder upstairs but with all the room doors open, still comfortable.
Now for the advice I need. The Phoenix is rated at 55000 BTU/h. We are looking at two possible replacements : the Pacific Energy Super 27 (72000 BTU/hr) or the Summit (99000 BTU/hr). I know those numbers don't mean much in reality but it is a way to compare stoves. Average BTU/hr will be greater for the Summit than for the Super 27.
I tried calculating the output we need for the first floor considering the loss to the second floor based on info from here http://www.stovefittersmanual.co.uk/articles/what-size-wood-burning-stove-for-my-room/ and I get about 53000 BTU/h. I also used another calculator, like this one : (broken link removed to http://www.thewoodburnercompany.co.uk/stove-size-calculator), and I also get around 50000 BTU/h. So I figured I would need an average output of about 50000 BTU/hr. Based on this : (broken link removed) the Summit is the way to go.
However, I just spoke to a salesman this morning and he told me that if I go with the Summit on my first floor, we won't be able to stay in the living room and we might even need to open windows because it will get too hot on the whole floor. Also, most retailers say that the summit is good for 2000 to 3000 sqft. From my calculations, it would be pretty well suited for my 1100 sqft first floor.
As you can see, I've done my homework but I'm more confused that ever.
Is the Super 27 still too small for what we need?
Is the Summit too big?
Can I buy the Summit and build small fires in it or does it have to be loaded quite a bit to burn clean?
The firebox is the Summit is 3 cu.ft. and the one on the Super 27 2 cu.ft. If I fill the Summit's firebox 2/3 full, will it give the same outpout as the Super 27?
What do I do?
What do I do?
