ryanwc
Nah, no need to phase them out. Video drones will cruise over neighborhoods looking for smoke. If you can't figure out how to run yours clean, you'll get your wood license revoked.
They can. But they run like an old pre epa smoke dragon. And in some cases it can damage the stove. The good thing is most modern cat stoves are much easier and cheaper to maintain and run than a downdraft Harmon.This an interesting thread since I might buy new instead of repairing my Harmon. Are you saying a cat stove can be run with cat removed?
Yes that is true if you only burn 1000 hours a year.You don't HAVE to replace it every couple years, if taken care of and washed properly they can go up to 10 years.
As per BK website:
Q. Do catalysts need replacing?
A. Yes. After a number of years, catalysts can loose their efficiencies. It is not uncommon to get up to 10 years or more service from a catalyst. Burning well-seasoned dry cordwood only can best prolong the catalyst life. If you are planning on burning boards with nail, paint or chemical treatments, or using your stove to burn household trash, you should not use a catalytic wood stove. Of course, all catalysts installed in Blaze King wood models are covered by a 10 year prorated warranty.
As per BK website:
Enlighten me please, why is my Harmon a downdraft? These Harmons(TL300) are not user repairable friendly which is why I'm considering new nextnseason. I personally don't care about the EPA until they can stop China and volcanos from spewing.They can. But they run like an old pre epa smoke dragon. And in some cases it can damage the stove. The good thing is most modern cat stoves are much easier and cheaper to maintain and run than a downdraft Harmon.
I have my Harman TL-300 for 10 yrs and has yet to need anything replaced. If and when i ever need to replace the fire dome package it will be similar in cost to replacing a worn out cat. Well worth it for the long burn times i get, which are much longer than my EPA Burn tube stoves.This an interesting thread since I might buy new instead of repairing my Harmon. Are you saying a cat stove can be run with cat removed?
Because the smoke path travels down through the combustion box which has caused problems for every manufacturer who has tried it.Enlighten me please, why is my Harmon a downdraft? These Harmons(TL300) are not user repairable friendly which is why I'm considering new nextnseason. I personally don't care about the EPA until they can stop China and volcanos from spewing.
Down draft refers to the air movement within the stove. With the bypass closed,the flue gas exits the stove at the bottom of the firebox instead of the topEnlighten me please, why is my Harmon a downdraft? These Harmons(TL300) are not user repairable friendly which is why I'm considering new nextnseason. I personally don't care about the EPA until they can stop China and volcanos from spewing.
No they cost allot more than a cat and most people struggle to get 5 years out of one.I have my Harman TL-300 for 10 yrs and has yet to need anything replaced. If and when i ever need to replace the fire dome package it will be similar in cost to replacing a worn out cat. Well worth it for the long burn times i get, which are much longer than my EPA Burn tube stoves.
They were around $300 unless they went up.No they cost allot more than a cat and most people struggle to get 5 years out of one.
Cats aren't that expensive.
The last one we did was almost 400 plus 50 or 60 for the gasket kit. That was on a 4 year old stove and it needed a shoe brick and 2 side bricks that the customer was going to do. That is pretty typical of what we see as far as maintenance time frames on them. 600 or 700 every 4 to 5 years.They were around $300 unless they went up.
Usually only an hour unless bolts break but that is uncommon.Probably a good bit of labor cost too.
Cat for the comparable princess is still under 200$ delivered and pops in like a vhs tape. Even cheaper for the Woodstock stoves.
They down drafted a little bit but nothing like the modern ones that cause so much trouble.Weren’t the old Defiants all downdraft and quite reliable? Only when VC introduced the frigile refractory boxes the issues started......me thinks
The two piece Fireback design maybe could be called reliable. The original single piece design was a major design flaw and effectively renders all of them unreliable. Sure, there are probably a few folks on the original single piece Fireback with no issues, but that was not the majority. It costs about $800 in parts to retrofit the original to use a two piece Fireback, but you basically have to completely rebuild the stove. Otherwise the orignal defiant is still a finicky stove, but it can put out some serious heat.Weren’t the old Defiants all downdraft and quite reliable? Only when VC introduced the frigile refractory boxes the issues started......me thinks
Some of the electricity does yes. But the percentage is going down more and more every month.Kind of like people buying hybrids they don't seem to grasp that where the electricity comes usually is burning coal
Because that's not going to stop India and China who are the major polluters of this atmosphere to change their ways. So why should the American people pay the price for something they can't fix.Some of the electricity does yes. But the percentage is going down more and more every month.
So can you tell us why you think doing nothing until we can fix all of the issues makes more sense than working at a problem one part at a time?
