I climbed on the roof today to wrap trash bags around my attic whirly birds. I usually do this in the fall but I procrastinated a bit this year. Hopefully it will hold a little more heat in.
Anyway I thought I would check the Chimney. The first thing I noticed was the top plate I siliconed to the Chimney had come loose on one corner. I didn't have any silicon handy, so I laid a brick on it to hold it down. I pulled the cap off to see how much buildup I had. Im going to call it somewhere between an 1/8" and 1/4". Probably closer to the 1/8" than the 1/4". It's a flexible liner and you can clearly see the corugations. It's dry and flakey too. I had some coals going in the stove and when I stuck my hand down the chimney to see how tight the stuff was stuck on, it went fly up in the air. The cap is a magnaflex cap. It doesn't have a screen it has maybe 1" square holes in it. There was some buildup in the holes but most all of it came off when I pulled the cap loose. I tapped the cap a few times and came up with a couple tablespoons of gunk. All in all, I think that's pretty good. I've gone through a little over 2 cords so far.
Do you think I need a mid-season cleaning?
