- Oct 5, 2009
- 9
My dream is to put the HI300 in a factory built fireplace.
1. Manufacturer says fireplace must meet UL 127..... check
2. manufacturer says flue must meet UL 1777... check (once I put a liner in my ex 8" flue)
3. Manufacturer says i need a 21.5" opening..... umm how about 21'ish??? Does anyone have the actual hieght of the unit "behind" the faceplate? The side profile in the manual makes the part of the unit behind the faceplate look about 1" or so shorter than the front of the unit. i'd take a measurement myself but nn one around here has one in stock so I'll have to wait until i can get someone on the phone and take an actual measurement
4. I'm also confused if I can remove the top smoke block that encases the damper lever in the ZC fireplace. It seems I would have to remove this part anyhow just to get the damper lever out, right? Do installers just cut this damper lever off? Or do you take this all apart to get the damper lever out somehow?? see picture
I will also be using a Flue offset adaptor becuase my flue won't match up with the HI300, Does anyone know the EXACT dimensions of those things? Its seems some are taller than others, and I need ever inch i can get. So i need the slimmest one
Thanks,
Thanks,
