Ashful
It has the option to come with legs. It's on my list for the new house
It does? I looked, but missed that. Would probably look a heck of a lot better (big Sirocco?) on legs!
Do you find that the cat stoves are more sensitive to using undersized wood (say 16" when a 24") would fit? I never had a problem using 16" splits in my heritage which is rated for 21" wood.
BUT, I am not yet convinced that a 2.75 cuft firebox holds enough btu's (no matter how they are dispersed) to heat my home for 12-14 hrs in the dead of winter. My jury is still out.
The winters are certainly more intense than yours due to the Northern NY climate, and she gets along fine.
Jags the Isle Royale lists a 20 hour burn time, is that not accurate?
Are any of the listed burn times?
Sure - I have had coals under a pile of ash 20 hrs later with a 150F stove top temp. That ain't heating my house in the middle of winter. I can get a real 8+ hrs of meaningful heat. My problem is that my house will go empty for 12+ hours at a time.
Thanks for the response but...
Not sure of the area you are talking about so I did a bit of research. Because I don't know where you are I selected New York, NY and based off of a 65 deg F base line:
Jags,
You can click on anyone's location on the left of the thread, beneath their avatar, and get their general area. I am at zip 13626 if you want to look specifically. NYC is a completely different climate. Northern NY ~ think northern VT and northern NH, about the same as me.
My buddy has an IR; it's a great heater. It won't make meaningful heat towards the end of a full workday, it just won't hold enough wood. I understand your situation completely, and that's exactly why I replaced my Woodstock with a BK.
Here is a nice looking stove at 4.0 cubic feet.
(broken link removed to http://www.hearthstonestoves.com/wood-stoves/stove-details?product_id=1)
I am going to the neighbor's house tonight, and I will measure the usable dimensions of the Princess firebox and post here tomorrow.
That's a non-cat.
I suggested the Equinox early on in the thread. No bite from Jags. Cat was not a prerequisite IIRC.
after reading all this I have come to the conclusion that you do not need a bigger/badder stove...you need a wood loading robot. With your skills and ingenuities (all of them) you should be able to whip up something in a few short hours....think "converting lawnmower into racecar, into cherry picker, into pitching machine, into wood loading robot" easy peasy lemon squeezy! I will be available for consultations and for musical interludes (begin Chariots of Fire! - Vangelis).
isn't that just like a robot to do....leave you there, alone with a cold stove. apologies. hang in there man...things might only get betterer.I tried - my robot said he didn't like the way he was being treated and left for the circus. Something about "elephant trainer". Little inconsiderate bastig.
