Hi all,
I have an Enviro M55 insert. Nice stove, no issues with it, but curious how I could add a UPS/Battery backup unit to my setup. When the power flickers over the winter, it kills the unit, and then it has to cool down and go through it's whole cycle before it starts blowing again. If the power is out a while, since the fan isn't running but the fire is still burning, I get smoke.
So I want to add a UPS to it. Right now, it is plugged into an outlet that is inside the firebox behind the stove. This is wired in metal conduit and has a junction box in the basement. From the junction box, the wire goes to a dedicated breaker in the panel.
I read that having a lead acid battery too close to a pellet stove is a very bad idea (assuming this true), so putting a small UPS behind the stove (hidden from site) sounds like something I should not do.
What options does that leave me, that would be considered acceptable per wiring code? I thought that I could add an outlet in the junction box, for a UPS to plug into, and then take the wire to the outlet in the firebox and take it out of the junction box, put a plug on it (making it an extension cord basically), and then plug that into the UPS. The UPS would be in the basement. I could always remove this setup when I go to sell the house as I'm sure it's not allowed by the code, but I don't see anything wrong or unsafe with this idea.
Thoughts on that approach, or other ideas?
Thanks.
Thanks.
