Identification Request: Vintage Insert
charlesryder
1
Denver, CO
Hello!
I’m trying to identify a vintage wood-burning fireplace insert in my home and (hopefully) find the original manual.
My home was built in 1961, but I suspect the insert was installed later. Maybe 70s or 80s.
In addition to the photos, here’s what I know:
  • Steel insert with a firebrick-lined, self-contained box.
  • Two hinged doors with four rectangular glass panels (two per door).
  • Insert body measures 26-7/16” wide × 23-5/8” tall, excluding the surrounding steel panel.
  • Black steel surround with convection grilles above and below the doors.
  • Integrated electric convection blower, operated by a rotary control.
  • No visible manufacturer name, logo, model number, or identification plate.
  • One rod at the top center operates the flue damper. Pull open; push close.
  • Two additional push/pull rods operate dampers at the bottoms of perforated steel plates running along the interior side walls. (They don’t seem don’t really do anything in practice.)
I’ve used it for about six years and had it professionally cleaned and inspected twice. I also removed and serviced the blower.
Any identification leads or historical documentation would be greatly appreciated! (In particular, what’s the appropriate gasket situation around the doors and glass.)
  • [Hearth.com] Identification Request: Vintage Insert
No tag in or near the blower control? perhaps a PC board with a marking on it. Any stamped numbers on the hinge side of the doors? you may have to feel around for them.
