Your also likely to get smoke with a conventional and more so with yours because of the extra passes through the water jacket. Not sure what kind of moisture your wood is at but I found that 25-35 percent was the best balance. With a right side up fire f the wood is to dry it will burn up quick, the greener wood slows that process down. The downside to that is more smoke. A good coal bed will do the most to minimize your smoke. But at the end of the day it is a conventional boiler and it is going to smoke.
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/168/168211-f5354ce8e51ba3135dfa74dfccf98ade.jpg?hash=HHJ3olcyIF)
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/168/168321-498d164a39341934bc2d6037d56dc1aa.jpg?hash=Q9JMPdgP9z)
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/168/168322-270089e576daf215cd8f0d0ee9f8a8e8.jpg?hash=ihHGHibxR1)
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/168/168323-a9cc43a90cdec4073d461077362063d5.jpg?hash=eeuhRBG5-R)
stop burning that scrap junk...like honda said you will NEVER get a cool coal bed established. Now dont get my wrong, i burn all my mill scraps up in my OWB....but i throw in only a few pieces a day when i load on top for that quick blast of heat (adn to get rid of it). HEDGE is the BEST stuff out there to burn and has the highest BTU count of any hardwood.....get as much of that stuff as you can....start stocking up on good hardwood wherever you can get, get it cut , split and stored for 9-12 months and you will never have these problems that you are speaking off. If you dont have any seasoned hardwood for this year try and find some ash to cut down....that stuff has a low moisture content naturally as is the best wood to burn "green." I burn mostly all oak, maple, hickory, ash, cherry and walnut. Having that 2-4 bed of nice coals is extremely important. my advice is to make your round or splits about 4-6 short the length of the firebox, this will leave a few inches on each side and ensure that you can stack a nice even load in there...hope this helps!
and foggy, at 630 I went out and all but a small piece had burned to nothing, water temps down to 156 from 170. So I reloaded again and let it take off. I have turned my differintial up to 7 degrees and I'm wondering if now would be a good time to turn it up 10 degrees. So my fan isn't running so often. What do you guys think? If I turn my differintial up some more will I get a longer burn time?
