I tried something new with our new Heritage this morning - choking down the flue damper a little. It's a 6" stainless, uninsulated Z-liner w/ a spring-loaded damper w/ pullchain inside the firebox - the damper "door" is actually way up at the top of the chimney about 40 feet up. I brought it down maybe halfway, maybe a touch more (i'll need binoculars and have to stand in the neighbor's parking lot to see it for sure) It seemed to really help reduce the air movement inside the firebox, which has been ripping strong even with the primary shut nearly all the way off. Remarkable difference in the appearance of the secondary burn - more mature flame, hovering nicely, not really attached to the splits, and also not getting sucked out the top too quickly. Was definitely still drawing well enough - nothing backing up into the room, even 45 minutes later.
I can only imagine this was very inefficient running the flue wide-open - sending way too much heat up the chimney and keeping not nearly enough inside the room, even w/ the primary shut off. Reading here indicated the primary SHOULD be enough to control the burn, but I really think the draft from this chimney was just pulling a ton on me...
This may be the critical operating parameter I was looking for to go over 400F (still waiting for my damned IR thermometer to show up). We got a good 7 hour burn last night - coals from 4 or 5 smallish splits were plenty hot to rekindle this morning, but it'll be very interesting to see if we can extend the burn even better now.
I had only originally intended for this damper to be a simple shutoff to keep birds, squirrels, bats, snow, sleet, and rain out and reduce any heat loss up the flue - but I can't imagine this is the wrong way to use it - right?? It shouldn't matter that the damper is on the top of the flue vs. right down next to the tee - right?? :cheese:
Curious if anyone else is using such a method / damper, and if I can expect to have to continually open it up and close it down, maybe only when it's a total cold start, etc. Hopefully I can not have to stick my hand behind the stove too much on a daily basis...
Thanks all for the helpful advice here!
