It would help if they knew what your question was, it didn't come through.
Add a couple feet of 3". That's what it is designed for.
Are you sure the wood is fully dry and seasoned? Damp wood is going to burn poorly.
EMT is not satisfactory. It's galvanized. Use 4" stove pipe. The damper in the flue is helpful to control the fire and improve heat output.
You don't need the parts in this kit. The 'funnel' is a 4" to 6" pipe increaser.I found this kit, black pipe 4 inch, has a funnel, I do not know much about stoves, but that funnel seems like a restriction, would it work better if the collar was 4" as well? would it improve things in my case? or make worst, no difference?
