I just completed installing the last of 3 plenum heat exchangers, into oil hot air furnaces that serviced our converted barn/home (two furnaces - one at each end), and a smaller farmhouse 50 ft away.  Although the weather has just started turning colder (it is about 30F today), it just seems to me they are not putting out the heat equivalent to the oil burners they are replacing.  I am using 16X18" units for the two furnaces in the barn.  These are "rated" at about 129,000 btu/h.  I measured the air temp coming up at the register at about 140F, when the boiler system was heated to about 175F.  As oil burners, I used to put in a 0.7 gal/min nozzle, or about 97,000 btu/h, and they would run for fairly short periods then shut off.  However, the heat exchangers seem to run forever, even with only a 30F outdoor temp, as though they are not really putting out that much heat.  I think they won't be able to handle it when it hit 0F or below.  I certainly don't believe they are putting out more heat than the oil burners did.  I haven't measured the exact supply/return temps on each of the zones yet - but both lines are very hot.  I am running 1" copper lines, and have should at least 8 gal/min as calculated by several approaches.  The supply and return line temps don't feel that different (this is very unscientific at this point, and I don't expect my hands to accurately detect 20F differentials), but it seems the exchangers are not extracting as much heat as they should, rather than it being a supply problem.  I feel I am not getting anywhere near the same heat out of the heat exchangers that I did with the oil burners, that theoretically should be putting out less heat.
I know this is a complex question, but in general, what experiences have others had on using these plenum heat exchangers of this general size?
There is a downside to using plenum heat exchangers that I am starting to see. Because they seem to run much longer, the fan electricity is going to add up over the winter. Eventually, I want to replace them with baseboard and floor radiant heat, which will be much more efficient electricity-wise. These units allowed me to get the system going quickly, and retain a backup heat source. However, as I am watching their performance, I am not impressed so far.
Does this match up with others, or did I do something wrong on the install?
