Hi, we are looking to buy a new 2020-compliant insert.  We had an old 80's Lopi slammer, which due to advice from all you fine folks here, we decided to replace (https://www.hearth.com/talk/threads/half-cord-for-3-weeks.178225/).
Our house:
The salesman at the store steered me toward the Lopi Answer. He thinks Lopis are just better built than PEs for similar cost. He mentioned the thickness of the steel, the door latch mechanism, and a few other things he thinks Lopi does better. However, the Answer is really small. We're not going to be burning every day or overnight. But when we do burn, we want it to really heat the house, especially during an outage. And I'm a bit concerned about getting wood into the Answer's firebox if it's not cut to the perfect length. (We buy our wood pre-cut and split.)
The problem with Lopi is that to get any bigger and stay 2020-compliant, you gotta go to the "hybrid fyre" (seriously, fyre?) inserts that cost quite a bit more, and we'd prefer to stay non-catalytic.
So should we consider the PE Super? It's not much more than the Answer and quite a bit larger. The other thing we like about it is that it sticks out a bit more. We're not looking for flush -- don't care about super-modern looks, and would like the heat to radiate some when the power's out and we can't run the blower.
Jotuls seem to cost a lot more, and since we're not going to be using it daily, can't really justify the expense.
Who's got advice? I'm very open to other suggestions.
Thanks!
			Our house:
- N. Puget Sound, WA (mild winters, few days into the teens & 20s but mostly in the 30s & 40s)
- Single story, 1900 SF
- Well insulated and sealed, just had some insulation and air sealing done
- Have central heating, this would be for secondary heat most of the time & primary heat during power outages (not that common currently)
- Unlined chimney in decent enough shape to accept a liner
Thanks!
