You definitively need something in front and you may need to remove the trim to get a hearth extension there. That would be true for any stove.
When you measure from the left side do you have 36" to the drywall under the stairs?
You could probably push the stove a little further back as the chimney would be considered non-combustible. Check how much clearance from the back corners of the stove to the sidewalls you still have then.
If Jotul does not want to answer your question directly, ask your dealer to call them.
If the intent is to have this installation inspected and insurance approved there needs to be more than just a fireproof surface. A sheet of metal glued to sheetrock is a fireproof surface but would not be approved. Clearances established by the manufacturer are the authority here. If the mfg. grants an exception for NFPA wall shielding then the inspecting authority "may" approve. What may be confusing is that NFPA does not list just one option for a wall shield. NFPA 211 table 12.6.2.1 lists 8 different options with varying degrees of protection.
That said with the new current dimensions just provided it now appears there is an issue for installing the F500. The rear edge of the side door opening is not 26", it's ~18" from the wall. I think that's too close for the 33% reduction to help. My guess is that is the concern of the stove shop too.
Correct. 36" clearance from combustibles is for an opening door to the firebox.Is the only side that needs those clearances the left side? Or does the right side need it too?
your answer could simply be "No, I always front loaded the stove".
The protection on this hearth for front loading is even worse than side loading.Just so we're clear - Nobody is going to be in your home telling you not to use the side door. God forbid something actually happens in which case you could potentially be asked about using the side door, your answer could simply be "No, I always front loaded the stove".
That can be remedied easier than the side clearances though, and will most likely need to be addressed regardless of which stove he chooses.
Salesmen are anything but authorities. Don't believe that? I have a bridge in Brooklyn that is up for sale, cheap.
If a stove shop tells me it's OK to use, and they sell it to me, I'm going to take their word for it that they know what they're talking about.
I found this thread doing some research. This member is local to me in NH. Her install doesn't look any different than what I am trying to do? What am I missing?
I can't find it, but not sure what are on her walls, and it seems like they use the side door with no issues at all.
So maybe there is some hope for me. I might reach out to her and see what info she can provide as well.
https://www.hearth.com/talk/threads/shes-here-yet-another-oslo-install.139631/page-2
