Ready to install a 6" X 20' stainless section of this heavy flex liner into an existing masonry chimney.  When laying liner on ground if it is pulled tight from both ends, it almost measures 21'.  If compress from both ends it is 20'.  I need to cut off about 2' to allow connection to top of fireplace insert and have the recommended 4" stub above crown.  I figure I should relax it a bit and make cutting measurements with the liner at 20'-6" .
Does this make sense or am I missing something?
