I thought I would bounce this one off you guys. I have read a great deal online and pretend to be just one of the uneducated masses that moonlight as a DIY'er on the weekends. Nothing more...so here is the situation....
I have a large (1900 sq ft) uninsulated basement with nice flat, block walls. I have very little moisture (just enough to keep a dehumidifier going) and never see any water run down the walls or on the floor,,,anywhere. With any uninsulated block structure, I do get damp looking areas in the corners of the basement where it is above ground. The below ground sections (90% surface area) show no discoloration any time of the year.
There is insulation on the outside of the block foundation below grade, not above. I do not know if the poured floor has insulation below it. My guess would be yes.
I have no plans to finish the basement in the next 3-5 years, if ever. Although, I want to start this project with the intention of being able to finish it at some later date.
I am not going to use any combination of foam boards and fiberglass insulation. Too many horror stories of fiberglass insulation getting wet and causing mold. Not an option for me.
This takes me down the decision pathway on deciding what type of foam board to use. EPS or XPS. The XPS claim to fame is that it actually forms a great vapor barrier and absorbs less moisture than EPS. The price is about double for XPS. For a large basement, that difference is quite large.
My question boils down to this. Does the EPS really absorb so much moisture that I would have issues if I was to drywall over it? Is it possible to put up a cheap plastic vapor barrier and then the EPS?
Anyone with experience?
