I am building a masonry firebox.
While it will LOOK like a fireplace, it will actually have my Jotul 3 wood stove in it. No smoke shelf just a clay thimble into a clay tile flue.
Yes, I'm using clay, not a prefab chimney. Decision is made, materials are on site,
I completely understand the clearances to combustibles for both the stove itself and the masonry unit in which it sits.
As per NFPA 211 there will be a 2" air space between the house framing and the masonry unit.
I will also hold the masonry 1" air space off of the house sheathing as the chimney rises up.
Now none of us want a 2" gap letting cold Winter air blow in!
What is the proper way to seal this gap?
How do you recommend I finish the interior wall finish to the masonry?
How to finish the exterior masonry to sheathing?
Finish the siding to the masonry?
What kind of insulation....... if any?
NFPA 211 talks about using metal flashing to span this space but is silent on insulation in that air space.
Also metal flashing inside the house isn't exactly pretty.
Yes, a permit is in hand, it is simply these small finishing details that elude me.
Thanks for taking the time to help.
Dave
Dave
