I am trying to integrate my E250 Wood Gun with (2) insulated 325gallon horizontal propane tanks into my existing oil fired system with 200 gallons of storage. It consists of 3 hi temp zones (Cast iron Radiators) and 2 low temp radiant zones PEX loops in floors, 1 Water to air exchange for forced air. 1 water to water plate exchange for Hot Tub.
My question is this, How does one go about wiring and plumbing the system to bypass oil burner without flowing stored heated water through the oil burner when it is not running.
Secondly, i want the oil burner to come on at 130 degrees when the wood boiler is no longer able to produce heat but only charge the existing 200 gallons in the system loop, not the 650 gallons of additional storage.
Do i need 1 way valves ? can i bypass the boiler by using separate circulatory pumps for the wood boiler and the oil boiler. Basically using static water pressure to bypass the boiler. ?
My propane tanks have 1.5' plugs in the bottom, should i plumb into them or just use a dip tube from topside with a T on the bottom to introduce hot water to the bottom of the tank and draw my hot water off the top of the tank for my zones ?
Are there loop designs out there that members can post suggest.? I can make up a drawing of my current system and members might suggest modifications I would be needed to integrate.
