BrowningBAR said:
The original article mentions that 15-20% is "the right band of firewood moisture". Which reads to me like the moisture count on a moisture meter. It mentions that "when you get much over 20% you start to see symptoms of sluggish ignition and the inability to turn down the air without extinguishing the flames." The numbers you listed are well into the 20+% unless I am reading it incorrectly.
The original article began with this:
"Properly seasoned firewood still has a fair amount of water in it, say
15 to 20 percent of its weight."
Moisture meters do not, and never have, given results in percent water by weight. They give results in total water in the wood divided by total weight of pure wood fiber contained within. I have tried my best to distinguish between these two methods of expressing moisture content, there has even been a Wiki entry regarding this. I cannot make everyone understand what seems to me to be a very simple concept merely by repeating it over and over. If you actually take the time to read both the EPA and the Canadian test procedures, you will see that both methods are used to express the required moisture content of the test fuel, but they will specify whether they mean "wet-basis" or "dry-basis" each time, and each time the correct (but different) numbers are used. Again, the meter reads dry-basis and the percent water by weight is a wet-basis (sometimes referred to in the literature as "moist basis") expression. Same amount of water present in the wood, different numbers used to express it.
There is no other way I know to explain this difference, feel free to continue to doubt it if you chose.
