Hello all,
I've been reading all the threads here and have to commend this formum as being one of the best. I use forums for pretty much everything in life and this one is great. A quick thank you to all the previous posters and the great answers as by just reading I have learned so much. Just wanted to introduce myself and run a quick plan by you pro's.
Steve from Long Island, NY with a home at 2000 sq ft. Center hall colonial, interior Masonry fireplace/chimeny. The room where the stove/insert will go is the lowest room on the 1st floor (think sunken den), the stove would be facing a large opening which leads directly to the staircase. The second floor is a center hall with 4 bedrooms and one main bath. The hall is around 12 feet long. The first floor is around 1100 sq ft. Programmable thermostats are located in the room where the stove will be located and in the master bedroom upstairs. New windows, new roof, regular pink insulation on all the exterior walls. I have sealed doorways, etc when a leak is felt. As far as circulation goes, the first floor layout is pretty open and air moves very well. I can cool the entire first floor with a 12,000 btu window air conditioning unit running on low. WHEW....not that that is out of the way...
My plan:
Found a brand new TNC-13i 1500 sq.ft rated Englander insert, WITHOUT blower, but including the faceplate for $300 as a lowes special order return. Hoping to get it today. The goal is to keep the den warm and maybe keep the first floor comfortable as we use oil heat and keep it around 64f to save as much money as possible.
The fireplace/chimney has been inspected and is clean. My plan is to install the insert, build a roxul/plate steel damper block off plate (THANK YOU to the "POOR MANS BLOCK OFF" post). My question is regarding the chimney liner. I can get non insulated stove pipe for inexpensive. It is the black rigid kind from lowes - 6". Will this be sufficient for the liner? or should I choose SS Flex? What about the cap? Do I just bring the new liner up to "just below" the existing rain cap??
Again thank you all for your help and recommendations. As a side note, I cant offer burning advice as of yet, but I have been a landscaper for years, have been an auto mechanic, amatuer cook, ladies man, and Financial analyst...(joking about the ladies man thing...) I would be glad to share any knowledge...Thanks!!
My plan:
