I posted this in another thread, got a few responses, but was told to make a new thread. Here's the original post and two submitted comments:
"I have a 930sq ft house - is the PE vista a good option for me in terms of having a enough heat? The main part of the house is open, with a narrow hallway down to the bedrooms. I've had enough of my ancient Kozi, live in a small Canadian arctic town (Inuvik, just south of the treelike) and a dealer is offering decent prices on the PE vs. the equivalent Blaze Queen (or whatever its called).
Any thoughts?"
Welcome to Hearth! I'm not one of the experts here, but have asked the same basic questions and I'm sure you will get the help you need. Here's a few questions that are sure to be asked:
What kind of construction is the house? Well insulated? Do you want the stove to be the primary heat source or a supplement? What other sources of heat do you have? Just how cold does it get there (I'm almost afraid to ask
)? What size is the old stove in terms of cubic feet and how well did it perform? Is the existing stove pre-EPA or why have you had enough of it? So many variables...
Good luck. You're in the right place.
and...
Bozol, welcome. Can you start a new thread? Your needs are different. You'll get better responses to a new thread.
PS: If you want a PE stove, get the next size up, PE Super 27 or Spectrum. It will provide much longer burn times and reserve heat for the -40F nights. But let's also talk about the BKs in a new thread."
___________________________________________________________________________________
As to the first response here are some points to consider: The house is a stick built bungalow built in the 1970s. It, like all of the houses here in Inuvik, is built on ~4ft high blocking (some are on pilings) to allow air to pass under so the permafrost doesn't melt. This means there is no basement. The house I think is pretty well insulated. It has r20 walls plus 2 inch foam board, taped, all around with new siding, it has new triple pane argon filled windows, the ceiling is r40 and the floor is r40 with 1.5inch spray foam all under the house. The stove would be expected to work on par with the current 2 year old gas furnace as the main heat sources. If it worked well I would burn more. The coldest we'll get is -50`C but the average winter temperature for November-March is probably -30`C to -40`C. It's cold
The old stove has a bit bigger dimensions than the PE Vista but I don't know exactly. It heated the house fine - the stove is right in the main room which means it heats the living, dining and kitchen pretty good. The bedrooms at the end of the hall can get chilly but I'm getting a blower switch installed on my furnace which should take care of that. The only problem with the old stove is that it burns way too fast and could make the house too hot. It's pretty old I think.
As to the second post: I'm nervous about getting something too big right off the hop because I don't want to be sweating while I watch TV or eat dinner. Also have to consider size in my available space. The Vista will be just smaller than what I have so far so I know it won't be a problem.
Let me know everyone!
Any thoughts?"
and...
The old stove has a bit bigger dimensions than the PE Vista but I don't know exactly. It heated the house fine - the stove is right in the main room which means it heats the living, dining and kitchen pretty good. The bedrooms at the end of the hall can get chilly but I'm getting a blower switch installed on my furnace which should take care of that. The only problem with the old stove is that it burns way too fast and could make the house too hot. It's pretty old I think. As to the second post: I'm nervous about getting something too big right off the hop because I don't want to be sweating while I watch TV or eat dinner. Also have to consider size in my available space. The Vista will be just smaller than what I have so far so I know it won't be a problem.
![[Hearth.com] Is a PE Vista the right sized stove for my house? [Hearth.com] Is a PE Vista the right sized stove for my house?](https://www.hearth.com/talk/data/attachments/77/77956-64c8b20bd577bd5d810c5bd354afcca9.jpg?hash=mffhBtlV6R)
tonight!![[Hearth.com] Is a PE Vista the right sized stove for my house? [Hearth.com] Is a PE Vista the right sized stove for my house?](https://www.hearth.com/talk/data/attachments/78/78017-4faf04882479a559cc324009e2a30763.jpg?hash=SDc70lcq9o)
