So I just had this installed on Tuesday.
The entire situation has been some what of a mess.
But here I am now and this is what I have.
I would appreciate feedback as I don't think this unit is installed correctly but fireplaces is something I don't know to much about.
the base does not look correct and once I install concrete board and tile I am not even sure how that would be finished off since you can see through. The trim looks short or I even think the entire unit should be sitting about a half inch below the hearth.
also the way the pipe connects to the top does not look correct at all. Isn't there a collar that should go over that? I mean they just twisted it on, bent those brackets and that was it.
Shouldn't there be complete clearance in the back? It does have the firebox but still...
i just don't want to mess around being fire. Also I thought I would ask on here before asking buck stove.
thanks for your feedback!
![[Hearth.com] Is this correct? Buck stove 74 zc install [Hearth.com] Is this correct? Buck stove 74 zc install](https://www.hearth.com/talk/data/attachments/161/161189-0fb99082f4438911d2575e92ff8f0f33.jpg?hash=fOqQSht_fj)
![[Hearth.com] Is this correct? Buck stove 74 zc install [Hearth.com] Is this correct? Buck stove 74 zc install](https://www.hearth.com/talk/data/attachments/161/161188-8d80522d80729354779be02596045150.jpg?hash=ZjistEWmAy)
![[Hearth.com] Is this correct? Buck stove 74 zc install [Hearth.com] Is this correct? Buck stove 74 zc install](https://www.hearth.com/talk/data/attachments/161/161205-c88d59cbb67c2099b243e06d1db3fe90.jpg?hash=1SDzYklJtv)
![[Hearth.com] Is this correct? Buck stove 74 zc install [Hearth.com] Is this correct? Buck stove 74 zc install](https://www.hearth.com/talk/data/attachments/161/161206-8ff9ef192d3e3080984223745e01eb49.jpg?hash=nmohVX8zuW)
