Okay, it’s the one for the pipe. It doesn’t have a probe, so the stove top can be 700 or less, but the “ flue temperature can be “400- to 250Go by stove top and flue temperatures. If the stove top is at 700º or less, it's ok.
Remind me, is the flue temperature with a probe style thermometer? If so, the 400º temp sounds low.
Ok, surface mount on single-wall stove pipe, correct? If so, 250 to 400º is about right.Okay, it’s the one for the pipe. It doesn’t have a probe, so the stove top can be 700 or less, but the “ flue temperature can be “400- to 250
Yes, that’s correctOk, surface mount on single-wall stove pipe, correct? If so, 250 to 400º is about right.
Okay sounds good. So this winter I should be good. I’m pretty sure it was the wood last year. Plus I was still learning, but I have firewood that been drying for a year.With the flue damper closed the flue temp should drop to about the same as the stove top or a bit lower.
Where can I get one of those ? I know Amazon has alot, but i don’t know which one to get. I know it will save me time, so I don’t have to keep running down to the basement..Just be careful not to overfire the stove. A remote wireless thermometer with an alarm is a big help at keeping track when not in the room.
Yeah and I think it was because the wood wasn’t really season, so I had to open the air control much open.. and thank you. I’m going to check out what you just sent meYes, I think that may be part of the reason the stove was overfired last winter. When the fire is starting up, the first 30-60 minutes need careful monitoring as far as timing turning down the air.
I have the Auber wireless system.
Wireless Thermometer for Stove Pipe,Chimney,Outdoor Wood Boiler Wireless Thermometer for Stove Pipe, Chimney, or Outdoor Wood Boiler [AT210-COMBO] - $129.99 : Auber Instruments, Inc., Temperature control solutions for home and industry
Monitor temperature on your stove or wood boiler from another room in your home.www.auberins.com
But when burn season comes in two months. I will let you know how it’s going. I have all the conversation from all my Posts, so I’ll be going through them.Yes, I think that may be part of the reason the stove was overfired last winter. When the fire is starting up, the first 30-60 minutes need careful monitoring as far as timing turning down the air.
www.hearth.com
With good, dry firewood, turn down the air as quickly as possible without killing the flames. If the draft is strong, use the key damper to tame it.
This thread shows the Auber with the T6 (same as Summit) firebox.
Starting a fire and running an EPA stove
Questions about starting a fire and avoiding a runaway stove come up so frequently I decided to document starting our stove. This is a Pacific Energy Alderlea T6 with about a 3 cu ft firebox. The stove is connected to a straight-up, 20' interior flue. The outside ambient temperature is 34ºF. The...www.hearth.com
![[Hearth.com] Is this good secondary burn? [Hearth.com] Is this good secondary burn?](https://www.hearth.com/talk/data/attachments/314/314446-7b79e1d4ec4ce9a80590acb783288b84.jpg?hash=d1t_4Na8Qu)
Thank you for the information again, and I don’t have a key damper. I didn’t think I needed one. This stove has the ebt technology.With good, dry firewood, turn down the air as quickly as possible without killing the flames. If the draft is strong, use the key damper to tame it.
Oh. I didn’t know. You can put one in. I thought it was in illegal To do it. Does yours have one ? So say if I got a key damper. It will only be used when the draft is to strong? I remember I can use it all the time like the timberline. I used to turn down the stove, and damp it down. It really made a big difference.Sorry, I now remember that your thread got hijacked by someone needing a damper. The EBT only works on the secondary. If the draft is too strong, then a flue damper is recommended. This typically is only with flue systems that are 28'+ tall but there are exceptions.
Sounds good, and mine is 15 inchesIt's not illegal. Our flue system is 20' tall so a damper is not needed, but I might add one for testing purposes. How tall is the flue system on the stove from stovetop to chimney cap?
So, I’m thinking bout getting one now.I have a 17’ flue on my T5. I can start my fire with the key closed. It starts better with it open though.
I find it’s a useful tool. Especially when the temps creep into the -10s and -20s.
