Posting for a friend. He recently purchased a Blaze King Princess 32. He had a Wonderluxe Wood Circulator before. Princess is his first Cat stove. He is concerned with some of the temps he is seeing. Just not sure if they are normal or not. First the set up…. Flue has two 45s, then through the wall to T clean out, then straight up 18 feet. He has an outside air kit as well. He loads the stove, lets it heat up to active, and flips the bypass over. 30 minutes or so after, his temps above the cat( on the stove top ) are over 900 ( maxed out ) according to his thermometer. He has shot it with an IR gun as well. His IR gun top end is 1200. It won’t even read it. Flue thermometer stays around 250-300. Is this normal stove top temps for this stove?
