Issues with new Archway 1700 install
woodheater
3
Tennessee
I contacted a local company to install a wood-burning insert in an existing masonry fireplace on an exterior wall. The recommendation was for an Archway 1700. The installers came out a couple weeks later and got stuck at the step of connecting the collar on top of the insert to the liner they ran up my chimney. My masonry prevented the parts from mating up properly. The installer was very apologetic and said that they would need to order an adapter box and would finish the install the following week.
I know there is a learning curve with these stoves, and every stove is different, as is every space. But I am just very underwhelmed. I do not get much heat out into the room at all. My stove seems incapable of the overwhelming amount of heat that every other wood-burning insert and free-standing stove is easily capable of.
A friend of mine who has lots of experience with several different wood stoves (free-standing as well as inserts) struggled for an hour to get a hot fire going in this insert. He got a hot start with no smoke coming into the room. We wondered if my wood is too wet. I borrowed a tester from a friend, and it all tests 11-17% with a meter.
No matter how I build the fire or how long I leave the door open (manual says no longer than 90 seconds, which seems ridiculous), I get about half the advertised burn time and very dirty glass the next morning (it’s supposed to be self-cleaning). If I go to bed with it choked all the way down, I wake up to cooled charcoal that didn’t burn all the way. If I leave the intake wide open, I only get a 3-4hr fire.
I am wondering if…
1. The lack of an insulated block-off plate is causing slow starts due to the entire chimney being a giant heat sink and by the time it finally gets really hot half the fuel is gone,
2. The adapter, while not causing smoke to come into my room when I open the door, is preventing optimized draft which chokes the fire out more than it should when I reduce the air intake for a long burn, and/or
3. There is possibly something wrong with the air intake.
The installer came back today to address some of my concerns. He said the guys who did the estimate miscalculated the size/shape of the fireplace, which is why they had to order the sliding adapter. He said they will go ahead and install a block-off plate, and that should help put more heat out into the room. He suggested leaving the insert door open for several minutes before I fetch wood to build the fire. This will help initiate a draft of our conditioned air up into the liner. He also said the air intake is very sensitive and I should probably aim for more like 50% closed rather than all the way or mostly closed.
We’re just very underwhelmed, especially at the price this install cost. Bummer of a first post.
Any ideas would be appreciated.
This stove is a variation on the Osburn 2000 insert which is a good heater. The problem most likely is not the insert, it's something about either the fuel or possibly the installation. If they put an offset connector on the insert in order to connect the liner, that will reduce draft. The should check and make sure it is well sealed.
How tall is the liner on the insert?
The symptoms do sound like wet wood. How was the wood tested for moisture content? On the outside of the wood split, or was the wood re-split in half, then tested on the freshly exposed face of wood.
If you open a nearby window an inch, does the fire burn better?
Thanks for the reply.
1. I went outside and split two of my logs. Outside of these logs tested 11% and 13%. After splitting, the exposed insides tested 20% and 24% respectively. So that’s pretty significant. The installer recommended using wood at 15-20% for a good burn.
2. The liner is pretty tall. I don’t have an exact measurement, but I have a steep roof with a tall chimney, and the liner runs to the top of the chimney.
Ok, good to know. If the liner is 2 stories tall, then draft is less likely an issue unless the offset box is leaky.
Did they insulate the liner?
