Jotul F100 Refurb
Todd
10,986
NW Wisconsin
Picked this up today for $600. 2006 model. Needs a new baffle, it was a major pain getting it out! Had to cut a front corner off after removing the top. Everything else seems ok except all the gaskets need replacing. I’ll clean her up and give it some fresh paint then I’ll install her in my workshop this Fall and see how it burns compared to my 602 CB.
  • [Hearth.com] Jotul F100 Refurb
Looking forward to seeing the progress! That'll look good in the shop too, although it may be a sad day to see the 602 go!
Reactions: Turbo89
Looks like a fun project. I'll be interested to see what the verdict is. It's prettier, but i suspect you may be missing the 602 for longer split loads and burn time.
Reactions: bigealta
Yeah I don’t really want to part with the 602. Probably just swap them out to try the F100. After taking the primary air apart it looks like it totally sits the air closed, no EPA stop. The secondary air comes in the back in two small holes covered by plates. Burn times may be better than I was thinking.
I have it all taken apart except the main base. The cement is still solid so I’ll leave it there and start prepping and painting. Also have to order a new baffle today, looks to be about $100.
Reactions: Turbo89
Everything is prepped and painted. Just need the baffle and gaskets to put it back together. The firebox side panels and bottom plate was a bugger to get back in place!
That reconstruction before and after photo is going to be so satisfying.
Yes indeed! I kinda like restoring these older stoves to their old glory. After taking this stove apart I really like how simple the design is. The box is cemented at the seams and bolted together. I’m surprised the cement is still solid after almost 20 years. Every bolt throughout is 10mm except the screws holding the glass. Every single one came out easy. Hardest part was removing the cement for the door gasket and fitting the firebox back together. I’m hoping the new baffle can easily be removed without removing the top.
Tood, i'm not sure about the f100, but i never had my jotul 3 (original )top bolted down ( not sure if it even had bolts to hold it down) and the 1st thing i did with my f400 was remove the Top's "shipping" bolts. No problem with no bolts at all.
Access is so easy without the bolts. I lift the top off a few times a year to clean and just inspect a bit.
Reactions: Todd
The F100 also has a gasket top and two bolts holding it on. If I were to install this stove rear venting it would be nice to just remove the top and have easy access for sweeping up the chimney but top venting the stove you would have to disconnect the stove pipe to remove the top since the flue collar is attached to the top plate.
Put it all back together, just waiting on a new baffle.
Reactions: Turbo89
I was going say that $600 more than I would have paid for it then i saw the the finished pictures and thought that was a decent deal.
Reactions: Todd
They were asking $900 and I offered $500 then we settled at $600. Used stoves seem to be priced pretty high around here. I bet I could get $1000 for it this fall but I may keep it and sell the 602, not sure yet.
Really nice job Todd, Yeah my stoves are/were all rear vented so that's how i always think about them.
I just checked marketplace for wood stoves and couldn't believe how many are on there. Saw a nice morso, jotul f100, 118, a pac energy alderlea t6, tons of clones, a bunch of fishers, and a nice looking insert for very good price.
Some were priced very reasonably, the f100 was $500 with some chimney pipe included.
Reactions: Todd
Definitely some good deals out there. About a month ago I lost out on a mint F100 blue/black enamel for $300. The guy that bought it flipped it for $1400.
Hey Todd is this the same Hearthstone as yours?
Reactions: Todd
Small break in fire
I can't believe you can have a fire today (even a small one). It's like a swamp here in NJ and been like that for a while. Only getting hotter tomorrow.
Reactions: kborndale and Todd
No I have a Woodstock Fireview. That’s a Hearthstone Heritage. I always liked the looks of those. At that price it’s definitely worth a look.
Reactions: bigealta
Only 55 for a high today! Yesterday it was very hot and humid in the 80’s also got 4” rain. Just fired up the Fireview to take the chill off. Lol
Reactions: bigealta
I asked the seller for pics of the interior and they said they don't have any. It's an hour and a half away. I'd be tempted to go check it, wonder if it is a better stove for my set up then my f400? I do like my f400 but if it's substantially better i'm game.
Wonder how old it is, cat or noncat? I think it has a little larger firebox than the F400, maybe a little longer burn time.
Not sure? the seller is no help with info. And at 500 plus lbs with not an easy way to take it apart for easier transport i think i'm gonna pass. if it was closer i'd at least take a look, but with my f400 doing a good job here not sure it's worth the hassle. Still it does seem like it could be a great deal for someone looking for a nice stove.
Reactions: Todd
