Jotul F500 Rebuild Questions
Emerel
16
Vermont
I recently bought a Jotul F500 and I’m in the process of rebuilding. It was over fired and the burn tubes were destroyed. I have bought a new burn tube unit and many other parts. I have looked carefully for cracks in places where people say they likely occur and haven’t found any. My question revolves around whether or not to break it down further to include the sides, front and back to re cement or just leave it as is. I can’t seem to find anywhere that shows how to do it. I don’t want to get in over my head so close to winter and not be able to use it. Does anyone know where I might find either pictures or video that will help me to decide? Thanks for any help you can provide….
  • [Hearth.com] Jotul F500 Rebuild Questions
Assuming that the base around the ash grate has been carefully inspected for hairline cracks and none were found... Then, If the seams are still well sealed then it may be better to leave the bottom end alone. There are air passages that can't have cement oozing into them without messing up combustion.
Thanks for taking the time to reply. That is exactly what I would be concerned with. Sometimes not knowing can get a person into more than they bargained for. It’s odd that someone hasn’t done a video on this. Seems like everything else imaginable has been covered .
My buddy bought one a year ago that was overfired. He had cracks in the top, on the corner of the bottom plate Right Back corner, i think 1 of the side burn plates and possibly somewhere else.
He did not find them till a few day after he got it home and cleaned it out very well.
Thanks for your reply. Did he take it completely apart and rebuild it? Any pictures? I’ve cleaned it out pretty good and haven’t found any cracks. I would love to do a complete resealing. But I am reminded of the time when I was a kid and took my brothers pocket watch apart….
I would re assemble without tearing down further. As long as you understand there may be a reason it was over fired. (Like an air leak). You may still have to do a complete rebuild but I’d avoid it if possible.
Reactions: bigealta
If you do a search in this forum on - F500 rebuild , titles only. Several threads on this topic will be listed. Some have pictures showing the process.
My buddy still has his in parts he has yet to rebuild it. He did have 1 part welded but it’s a work in progress. Not sure if his is even worth trying to rebuild. Sorry he’s in Utah so now pics.
Hi All, after seeing pictures and diagrams I decided to do a complete disassembly and rebuild. It just didn’t make sense to me to have invested in so many new parts and just hope it would be ok. After removing the left side it was apparent that it was the right decision. The old stove cement was totally destroyed. So now I can stop debating myself and get on with it. Thanks to those of you that sent messages and I would welcome any other wisdom that can be sent my way….
Taking it apart bit by bit. So far only one bolt head has twisted off but there is plenty of bolt left to work with to get it out. Gonna hit it with pb for awhile then some heat. Actually the bottom bolts that hold the front and back panels down were little more than finger tight and came out like new bolts. Found multiple pictures on this site that were very helpful and in particular some by scra99tch. Also thehouseisonfire said it wasn’t really that hard to get apart with 10&13 mm sockets and that he was glad he did it. I have to agree. It seems like doing all of the re-cementing in one session is the way to go. I read somewhere it could be done in stages but how would you fire cure it? Also, I haven’t found any cracks anywhere . When I got the stove it had a half inch piece of plate steel covering the inside bottom and it may have spared that damage. The burn tube manifold on the door side was completely destroyed. The new one sure looks pretty….
Are you going to repaint it?
I have been debating that. As I get closer to getting it torn down and cleaned up I will have to make a decision. It would be nice to have it be pretty but I’m more interested in having it work as designed. Any suggestions on best paint? Some folks like paint others use polish. My first time doing this so no opinion yet.
Don’t use polish. I had considered an F400 rebuild. It would have gotten a nice light color from stovebight. I was going to get a light blue.
The plate over the grate isn't necessary if one is dealing with a troublesome ashpan door seal. Just let the ashpan fill up to the grate level with ash and leave it like that.
Definitely don't use stove polish. If painting, Stove Brite satin or metallic black work well. Be sure to prep by wiping it down with acetone or denatured alcohol first to remove any oils or PB residue.
Reactions: Emerel
I just finished doing a complete rebuild of my V1 Oslo 500, take your time, document as much as you can. Get Thurmalox satin paint, and a gasket kit from Nick at Kingdom Wood Stoves, get 5 cans of paint at least, and paint while its apart. I used Rutland Furnace Cement, (in tubes) and think it's a terrible product. You can't mix tubes, and while you're applying it to the channels that need filling, you'll get a nice puddle of black water injected from the tube occasionally. If, (when), I rebuild my stove I'll try Hearthstone Furnace Cement.
https://kingdomwoodstoves.com
Reactions: Turbo89 and Emerel
I honestly don’t know what the plate was for. It was in it when I cleaned it it out at home. I have some denatured alcohol I’ve been using after scotch brite work. Seems to work really well. Your advice of just letting the ash fill up will work for me as I generally prefer to clean out from above. Thanks for your advice.
I just bought some tubes of rutland. I was thinking of also having some in tubs. I hope I don’t have the same issue that you had
Thanks for your insights!
