Jotul oslo f500 Rebuild
Nov 5, 2026
4
Garrison, NY
I am in the process of completely rebuilding an jotul oslo v1 f500. All parts have been sandblasted and cerakoted and dry fit together. The first parts i am assembling are the bottom and inner bottom. I remember speaking to kingdom wood stoves and they stressed to "go heavy on the cement when marrying the bottom panels. i Plan to caulk on the red lines i highlighted in the picture. Im using rutland stove cement.
Since those are the mating surfaces should this suffice? Or does anyone recommend i apply additional cement in between those lines?
Also since no torque specs are provided from jotul is the ol' goodentight approach valid? or should I not compress the panels too much. I planned on using clamps before tightening screws.
I dont fully understand the purpose of the cement, since i know many stoves crack from overfiring or improper cementing. I would almost imagine the metal parts would want to move independently to prevent friction during expansion and contraction. Yes i fully understand this is a difficult build as well, but im going to give it a shot.
  • [Hearth.com] Jotul oslo f500 Rebuild
Reactions: Todd
The stove cement is to.make the joints air tight.
I would put cement on both mating surfaces. It will ooz out around the seams but that’s ok, just wipe off the excess. I don’t think cement should go between those red lines just in the grooves. Good question to ask Kingdom Wood Stoves.
