Jotul F500 vs Blaze King princess insert
BKVP What is FBV?
Todd It is not an open floor plan. But the family room the stove is in has a opening to the rest of the house at one end and the other end.
Also the one end is right beside the stairs going to the second floor. We get pretty good circulation but I would like more to reach
far rooms upstairs. I did put a fan in the upstairs hallway blowing cold air toward the stairs and stove. Over all it seems to work
pretty well.
Firebox volume, I presume
Reactions: BKVP
I have a PI29 insert on a 30' exterior brick chimney. I installed a key damper 4" above the insert adapter. Had to drill a hole in the front brick surround to connect a steel rod then clamped to the key damper to make it work. Not the easiest to do so keep that in mind. I have a manometer to measure draft. Prior to damper, the stove would run .20 wc on high in cold weather. With damper it drops to 0.17 wc. Not a real big difference. I have never gotten anywhere close to the 0.08wc recommended by BK. Still, the unit chuggs along just fine and I can get 12 hour burns with ease. Fan is definitely noisy, a constant hum so you have to get used to that. For me the 8am/8pm load cycle trumps my use for fitting into my schedule. Thus the stove compliments me rather than me complimenting the stove.
Reactions: GG Woody
To put in a damper I have to move the stove out away from the fireplace opening. That would not be easy. It is up off the floor on a hearth.
I have not measured the actual length. Close to 30 ft is my guess. Thanks for the info spudman99
For the F500 - If you have the 2 unrestricted air holes in the ashpan housing sides walls, try putting a magnet over each one or a bolt in each one. There is a thread about this somewhere here. It has helped a few others with drafts that were to strong.
Ok so plan B would be to let the ashpan and the entire housing fill up with ash. That way if there is any air entering thru the ashpan housing the ash will block it.
Of course that means not using the ashpan, but if you don't see any difference then at least you know the ashpan housing is good and not letting extra air thru.
If you can get your drill and long 1/4” bit lined up I don’t think have to move the stove if you can get your hand up to the hole. You definitely need to remove the baffle. Might be a two person job.
