I can tell you that is not the heat shield, seems to be the back of the stove, but hard to tell. If so, very replaceable. It will involve some disassembly and re-cementing, but like jotulguy above says, its doable, then you have a beautiful 2500 dollar stove. I've repaired many jotuls myself, being new, this one will not be bad to work on. Good luck with it, the Oslo is one of the best cast stoves available in my view. l
Oof! That could pretty much be the rest of the story.Looks like around $977 for the backplate.![]()
If you look at the pic you see that the pallet was dropped. The stove should be sitting on the top boards. The guys delivering my F3 did the same thing and broke the door hinges, which are cast into the frontplate, off.
I'd be inclined to go look at it, confirm that what we see here is the only damage, then low-ball him. If you are a handy guy, you should be able to handle the necessary work, I would guess. It might be worth it if you are parsimonious in nature.yea unless you can get it for like 300-500 I would pass too.
I sold my 3 season old Oslo for $1500! I'd just look for a gently used one. It sure doesn't seem like its worth that kinda money to me. This guy is just passing on his problem to the next guy. IMHO.Or maybe find another F500 with a different issue, like a cracked base.
Interesting. Must just be the wood stoves. I sold nine GF300, GF400 and GF600 Jotul gas stoves and they were all on top of the pallets. One GF400 still in the garage on the pallet.
