New burner here...Using an Osburn Matrix 2700 insert.  I'm getting better at managing the fire, but am still learning.
Would appreciate any feedback you guys can offer. Since this is my first season I am admittedly using purchased wood, which I can't say for sure has been seasoned as much as it should be. I have yet to buy a moisture meter.
1) How long should it usually take before I can close the door? Assuming I have some kindling burning and possible 1 small log. It seems even with the air open all the way, closing the door almost snuffs out the fire.
2) Similar question. How long should it be before I can turn the air 1/2 way down, or all the way down? This seems to take a good while and also sometimes almost kills the fire.
3) What's my best option for an overnight burn? I've tried it a couple times...loading a fair amount of wood to a good hot fire, then turning the air all the way down. In the morning there are just barely a few hot coals.
*Should I leave the automatic fan on?
4) Is there a way to burn overnight and not soot up the glass? Each morning I wake up to find the glass quite dirty.
5) Once the automatic fan kicks on, shouldn't it turn back off when the stove cools down some? It was still running this morning, even though the fire had long burned out.
Thanks
Thanks
