Got a question to find out if I wasted a bunch of money last year of if it's necessary to keep an unheated portion of my water supply heated with a space heater.  I am in the country on a well.  Out of the well the water goes into my shop which is not heated.  There's a small corner where the previous owners had put a bathroom (all unhooked now due to frozen lines when the place was empty) and then the pressure tank/water softener is in there.  2 walls of the small area are 2x4 w/ insulation and the other 2 are cinder block insulated.  From there the main to the house goes underground to the main house and comes up an exterior wall and actually above the ceiling into the attic space (under insulation but still meh).  Kitchen sink and original shower are both exterior walls.  I have to keep that shower dripping regardless in the winter to keep it from freezing once things get below about 20 degrees.  Because of the water path that actually keeps all of the pipes in the house except for the kitchen sink moving if I drip both the hot and cold just a little.
Here we get into the question last winter I tried to keep that pump room in the block building above freezing. Cost about $90/mo for a space heater in that room which is just crazy to me (measured off a killawatt). If the rest of the house has to drip and that water does have that slow movement anyhow do I need to keep that room above freezing? Or will I risk freezing the pressure tank? It's a fairly small one only 20g or so. Water pressure is set about 45/60 I believe so it cycles pretty often. Figure the salt in the brine tank for the water softener will keep it liquid.
If I do need to keep some heat in there I may end up getting a small vent free propane ice shack heater or something similar to see if I can do it cheaper than the electric route.
Not going to be in the place long term so I really don't want to replumb the entire place to get the pipes off of exterior walls and out of the attic. It's on a slab anyhow so not really anywhere to go with them.
