Kelly Perfect Restoration
walhondingnashua
700
ohio
A lot of conversation is generally about the new stuff but I thought I would document my restoration of this True Temper Kelly Perfect felling axe. It's a barn find from my old family farm. Any input or experiences anyone would like to add are welcome.
[Hearth.com] Kelly Perfect Restoration
Reactions: Sean McGillicuddy
Lots of good info on handle replacement, google, you tube, etc..
For the metal, I have a recipe I've been using that's home made. Works well, is cheap and easy on the metal.
1/2 gallon of white vinegar
1/3 cup of salt
1 of those yellow squeeze lemon juice bottles, which I think are around 6- 8 oz "real lemon" lemon juice
you can reuse it and reuse it which is nice.
For real heavy rust, leave it on for 12 + hours, doesn't attack the metal, and you can use a scotch bright if you need a bit more removal. Give it a try. I've put in heavily rusted parts and tools for long periods with great results. I strain the mix and pour it back in a jug to reuse. Cheap and works.
What are you looking to do? Do you want new metal? Do you want to keep any patina under the rust? Is this a wall hanger or going to be used?
One other thing, if you do the safe rust removal recipe I posted, wipe it/spray it off with a general cleaner or brake cleaner, etc., when you're done and oil/grease that thing up asap. I use fluid film on my antiques and older tools because we're high humidity around here. It will start to rust again almost immediately if you don't follow up with it a bit.
Also, if you try the recipe, take some pics. It's a gentle but effective recipe.
Reactions: duramaxman05
I just put it in the mixture of vinegar, salt and lemon juice. Going to give it a few good soaks and scrub it with some bar keepers friend as I saw on a youtube video. I haven't decided yet if I can going to polish it to a shine (I did this with an unidentified double bit axe I bought at a flea market) and I'm not sure if I like it. I may just see how this turns out without a full polish.
I think I want to make it a nice axe I use and hang on the wall. I like old tools and plan on a display wall in the garage but I also don't want to be afraid to pull one off the wall and use it.
Go to Buckin’ Billy Ray Smith on Youtube and view some of his axe hanging (installing a handle) vids. Here are a few.
One thing I am not sure is mentioned in these vids is which side of the axe head goes on the handle first. By carefully measuring, you can see that one side of the axe head hole is wider than the other. Some people might think that the wider side of the axe head goes on the handle first, but that is not so, you need to put the narrower side on the handle first and progressively carve the handle down so that the handle goes out the other side by at least a half inch.
The reason this is so is that the wider side needs to be to the outside end of the handle so that there is room for the wedge to expand the outer end of the handle so as to tighten the handle onto the axe.
This goes into the step-by-step process of fitting the handle to the individual axe head.
watch
This, while long, has a good section on fitting the wedge.
This has a good section on cutting and extending the kerf to fit the installation.
Reactions: D8Chumley and EbS-P
I will watch these. Anyone with recommendations on where to get a handle? I can look at TSC or local hardware store and check for good grain, but are their good online sources?
never buy a handle if you can't physically look at it for grain direction and heartwood/spring wood. Look through a pile of 30, and you'll find 2 good ones.
Reactions: DodgyNomad
Done with the vinegar mixture and all rust cleaned off (thanks dodgynomad, I will be using that again). It has very little pitting and after rubbing some 3-in-1 oil on it, I think I will leave the finish as this. I have fully polished an axe in the past but I really like the way this one looks.
Next step is to clean up the edges on the poll and get the edge how I want it. I think it will be used for general chopping/ felling/ limbing and trail clearing.
  • [Hearth.com] Kelly Perfect Restoration
That turned out great. Been a good combination for me, and I have done a few hatchet and axes with it over the years and have been happy with the outcomes.
I've done some deeply rusty tools and some finer antiques, and a lot of classic car parts and it never has let me down. I just strain it through a paint funnel and pour it back in the jug and use it over and over until it's muddy garbage. Cheap as I am....
I do a fair amount of media blasting also, but this concoction has its place for sure.
I didn't mention that I have a Kelly Perfect that I use regularly. It's a great axe, but mine is a lot more beat up than yours, as it has been hit on the poll too many times with a big sledge when splitting over the years, so the edges are peened over. Good axe.
Its actually got me interested in the history of the company. I have read The American Axe and have picked up some history but I think Im going to be doing a little more digging.
Turned out very nice. I have an old Keen Kutter I restored using the same method.
This has been a huge debate for a awhile. If you are a beginner at hanging axes I would suggest going to the local hardware and buying the straightest handle you can find. This way if you screw it up you are only out $14.00. There are places online with perfect grain orientation and no grain run out and all the things all the the YouTube bushcrafters tell you are important. I say F all that non sense. Plus all the boutique handles are usually sold out or crazy expensive. If you feel you need or still want a boutique handle look up kilinger on you tube or Google kilinger axe handles. Plus, Bucking Billy Ray is cool and all, however, there is a new kid on YouTube doing a real good job with axe videos. Kevin kevech. Check him out too.
I make my handles mostly out of oak 4x4s I salvage from pallets. I have made some out of hedge. The hedge are about unbreakable but it a longer process to fashion them.
I bought what I think is a pretty good handle from TSC. I checked the other local hardware stores and this one seemed to be the best of the bunch. The grain is pretty straight and oriented well with only a little grain run out. Best of all it was straight. I looked at maybe 25 handles between the 3 stores and went with this one.
I've been busy with other projects lately but will get back to this soon. I am going to order come of the conical keys just to try them rather than the standard V keys that came with the handle.
A 4in hand tool or wood rasp works great for shaping the handle so it slides in the eye nicely. A palm sander with 80 grit works to, however, it just creates a lot of dust though. Don’t be scared to thin the handle down. Hardware store handles come super thick. Don’t be shy to shorten it some too. I’m guessing it’s a 36” handle? I’m also working on hanging an axe with a hardware store handle. I’m experimenting with thinning it way down and shortening to about 30”. I may loose the whole fawns foot but that’s ok. You won’t know what you like until you try different things.
Something to keep in mind: compare the head of your Kelly to another that has little to no use. Make sure you have enough bit left to make the whole endeavor worth while.
Just got back to this project...
I spent some time on the bit and really cleaned the edge up. I worked to keep the profile for a chopper. I feel pretty good about it. Not to pat myself on the back, but its probably the best work on an axe edge I've done lol (but its also the most patient I have been as well).
I also have a few hours in the handle. Scrapped all the varnish off and took a bit off of the lower part of the handle, above the fawns foot. As heavy as the head is (I never weighed it but I'm sure its between 4-5lbs) so I wanted a good bevel into the fawns foot. The handle grain runs parallel with the head. Just starting the hanging process. I've hung a few handles before on tools, but never anything with lugs, so it will be a learning process.
I will update again once its hung and I move to finishing it.
PS- The Buckin Billy Ray videos have been great help, along with entertaining.
[Hearth.com] Kelly Perfect Restoration [Hearth.com] Kelly Perfect Restoration [Hearth.com] Kelly Perfect Restoration
Nice work 👍
I’m going to try that rust removal recipe this summer. Last summer I tried soaking some mildly rusted parts in a container of evaporust. A day, week, several weeks. No change.
Nice handle! Take it slow while fitting it. Remove little bits of wood at a time. It's easy to remove too much!
That's looking great.
FYI, I have seen some folks use Coke as a rust remover for cases like this. The carbonic and phosphoric acids in it seem to do a good job.
I use electrolysis it removes everything except the metal
Hook up the lead and hang it in the tank,check after 24 hours repeate if nessary
I set it up to restore cast iron pans,but it has cleaned bares rusty chaines that wouldn't bend
found a rusty pipe wrench that wasn't usable,but id now.
Found a short 20 ton hydrolic jack that the release screw was rusted tight,hung it in the tank halfway now i have a short 20 ton jack that works.
Reactions: tlc1976
I've used it on a few old tools. I haven't had to use it for years, but it's a good tool for the arsenal.
Finished hanging it today. I regret using a bought wedge. It was poplar and soft so it was a struggle to drive it well. Wish I could have drove it a little deeper before it started to break up. I still think it will hold well. Never used to conical wedges before so we'll see how they hold up.
Just a little painting left on the handle, maybe stain and then linseed oil.
Reactions: Jags
