I've got a Drolet Blackcomb 1.9 cf. stove . 23 ft . of inside chimney lined with 5.5 smooth wall steel liner, and 3 ft. of 2 wall pipe with 2 - 45* . 1 at stove and 1 at chimney. VERY good draft
I've got lots of silver maple to burn . burned 3 cords last winter. got 8 cords left. we all know it burns hot and a bit faster. however I did notice the silver maple can get a bit out of control ( over burn or run away ) only once and a while if you are not paying attention . ( small splits - to much intake air or to good of a draft ) .large splits and less air made a HUGE difference. almost perfect.
once we got it figured out we're good to go. heating the entire house from the basement. me and the wife just love burning .so I got a DSP key damper to help control the draft, that I learned from this forum ( thanks ). my question is why do some dampers look like they are solid and totally close off and some are not as closed off and much less restrictive like the DSP that I got ??
There is no law that says anything has to be made to UL safety specs. There are key dampers that are safe and there are key dampers that are not safe.
